Rnse mk1 aux problems
Bowers155
Hey guys bought an aux set up pinned correctly in to my rnse go to code it from xxx1x to 5 set it and still does not let me select it from the menus only on 550sw do I need 650 or newer and where can I down load such update ?
Hey, I was going to post the exact same problem i'm also experiencing :frown:, same version hw with the same questions!! what is the exact code you updated to?
More info on my issue..
I've just coded in AUX functionality and connected the relevant plug\cable I purchased from ebay, coding update has been accepted for the Navigation module (37) but I still do not see the AUX functionality on the RNSE
I removed the analogue TV last year but didnt code it out so I thought it might be that as they both use the same input as way of the locking plug on the back but still no diff. Tried playing about with other valid codes but still nothing. Infact when I code out the CD changer as a test, that is still accepted as far as coding is concerned but the option is still visible to select 'CD' and I can select and play my CD's as normal. At a loss, anyone have any idea's what I might be missing?
a relatively straight forward task but i'm at a loss. I have not previously had any issues with coding, do you think this might be one for Ross Tech support or maybe my old RNSE is playing up? I appreciate this could be one of many things at fault like the cable i've purchase but I though if I code it in irrelevant of the presence of the cable input the option to select AUX would be visible once coded, correct?
Hopefully someone can help
I've just been helped out by another forum member you need to upgrade to sw650, give me a shout if you need help doing so
Did you rest your RNS-E by holding down Radio and Select, I made this mistake as the weekend and its all I needed to do for the Aux function to appear after coding :)
936
876
