RNSE FIT - Audi A3 Black Edition
selector007 Dec 6, 2012
  1. selector007
    selector007 Member
    47
    I've been looking around for a sat nav to fit my nearly new Audi A3 Black Edition(2010). I have decided to purchase the RNS-E navigation MK3 LED 2012 G Part number: 8P0 035 193 G.
    I have looked at previous threads and also looked at the sticky on how to fit the rnse sat nav but am slightly confused as i thought if you have a Multi function steering wheel it was the case of a straight swap apart from adding the gps antenna am I on the right lines?
    As the sticky suggests swapping some wires and using software to activate some functions.
  2. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,663
    116
    It is a straight swap, apart from adding the GPS antenna and swappin some wires.
    If you have BOSE then you need to change the position of 1 pin and if you have AUX, you need to move 3 wires to a seperate plug.
    Would also need coding to your car.
  3. selector007
    selector007 Member
    47
    What does the coding do?
  4. A3Kent
    A3Kent Well-Known Member Team Daytona Audi A3 S-line owners group TDi
    1,570
    249
    Make it work properly with your MFSW and DIS etc.
  5. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    If you do a search, I did a step-by-step of the install including moving the BOSE pin.
  6. reserves
    reserves Member
    55
    Whereabouts are you based, lots of people can help you with the coding.
  7. selector007
    selector007 Member
    47
    Anyone in the Leicester area up for helping with coding or even fitting?!?
  8. icekay
    icekay Member
    79
    ahhhh a fellow leicesteronian ! Where abouts do you live ? Not got a vcds but looking to buy and fit a rnse myself.
    where are/have you purchased your rnse from ?
  9. WALTO TDI
    WALTO TDI Member
    293
    12
    Any one have the correct part number for the steering wheel controller needed to fit MFSW to RNSE
  10. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,420
    9,422
    Im pretty sure you need a highline module. What number is the one fitted at present? I will look see what the module part no uou need is:) x
  11. cdj3.2
    cdj3.2 Member
    44
    I'm at houghton, have vcds :yes: willing to help!! Carl
  12. WALTO TDI
    WALTO TDI Member
    293
    12
    Hi Sandra my controller ends in suffix A and was told by RNSE installer that it doesn't support anything. I have no muse yet so I am about to purchase but obviously want to get all the right parts. I also plan to add cruise and Bluetooth so the controller will need to support these. Any ideas?
    thanks
  13. mike foster
    3,967
    8P0 953 549 F is the control module required for mfsw. It also supports cruise control.
    Bluetooth is a separate unit that does not require a separate control module.
