RNSE-Does it have an AV input?
jdp1962 Mar 30, 2014
  1. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,183
    2,662
    Pretty much as per the heading. I've seen an add-on DAB that uses a phono AV input rather than FM modulator to connect to an existing head unit. Could I add it to an RNSE?
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,705
    643
    There is Aux-in on the RNS-E, however if you video imput then you need to buy a media/video in. IMA Interface CAN
    jdp1962 likes this.
  3. hades-
    9,481
    646
    as above you can fit the av in
    jdp1962 likes this.
  4. jdp1962
    8,183
    2,662
  5. jdp1962
    8,183
    2,662
    Sorry to bump this open again, but if I fit an AV input to the RNS-E as above, am I right in thinking some VCDS coding is also necessary? If so, what code(s) need changing and which menu(s) are they in?
  6. B5NUT
    3,705
    643
    You need to code the RNS-E for TV so add 1 to the last digit of your current code.
    • 0xxxxx?: Equipment II
      • +1 = Standard/Basic Value - Add to the Sum of Options below
      • +1 = TV-Tuner (PR-QV1/QV9) installed
      • +2 = CD-Changer or iPod/USB-Interface (PR-7A2/7A5/UF1/UF2) installed
      • +4 = Multi-Function-Steering Wheel (MFSW) installed
    jdp1962 likes this.
  7. jdp1962
    8,183
    2,662
  8. jdp1962
    8,183
    2,662
  9. B5NUT
    3,705
    643
  10. jdp1962
    8,183
    2,662
    Ah, so I need to buy that unit as well as the interface lead, yes?
  11. B5NUT
    3,705
    643
    Yes that's the main unit, without that the lead is usless.
    There are two versions of the IMA the plus version which controls devices listed on kufatec's web site and the basic version which gives no control but is a lot cheaper.
    jdp1962 likes this.
  12. jdp1962
    8,183
    2,662
