is there a spare room going a begging if any of us are in that neck of the wood LOL
Dont see why not, I'll update when I move anyway so no worries, we were hoping to build a new family house for us & her parents, the italian thing, but not sure yet but I'd like a double garage with bench for work etc I think like Marc's got from his images I've seen.
Anyway I've managed to permanently fix the selector knob on now as below, the issue is it doesnt just fit on, it sticks out to far as I think Marc has found, the inner part of the knob rubs on the outer part of the fitting on the rns, so what I did was grind all the of new internal fixing of the new knob down & left it with about 2-3mm still raised inside, I then trimmed the new knob on the bottom so it sunk further down into the RNS, dremel worked a treat if careful so doesnt damage the chroming & as you cant see the bottom of the new knob as it hidden then it doesnt matter, I also gave the bottom a tapered edge internally to also stop any rubbing, then I dremmeled out the inside of the new knob white plastic to a thin layer not touching the outer casing so also doesnt rub this might require some superglue to hold the inner white plastic casing against the outer casing to also stop rubbing, finally as you have to glue it on to the rns, you have to stop the glue from dropping down into the rns/selector knob so it doesnt get stuck in place, so I fixed a small washer to the fitting screw head on the rns so it gave it a kinda lip not to big to block the led light but enough to hold the glue within the new knob, I used some epoxy glue mix of the 2 chemicals like araldite & as its runny from start until 5 minutes I let it react until it started to become less runny then applied some to the rns fitment head & around the washer head, stuck the knob on & aligned the edges so centred & also check its level from the side view of rns & left for 10 minutes to set, now it doesnt budge & works perfectly.
job to do but well worth it.
Only bit annoyed me of now & no doubt you is I managed to delete the images while doing but here's finished job anyway, whoops.
& before anyone asks I'm awaiting for the wider hazard button to close the gap, as they changed it after I got my kit & I upgraded to the surround with the small alum bottom trim
