RNSE, BT and SE K800i
simonwjones Jul 25, 2006
  1. simonwjones
    simonwjones Member
    366
    Just received my K800i last week and it was able to sync with my RNSE straight away. all functions are available on the BT including both SIm and Phone contacts.
    What I have noticed is that the BT pairing will keep dropping and reconnecting if not on a call. No issues when the phone is in use.
    THE BT module is the latest version and the RNSE the latest firmware and disk. There are NO updates of firmware avaiulable for the K800i yet.
    I know the problem is the phone as it works perfectly with my old Nokia 62310i and my sons K750i.
    Problem is I like the phone and dont want to swap.
    Done a bit of research and found that there was similar issues with Treo 650's if speed dials were used. Ive deleted mine and thought it had cured it, but apparently not. All the Audi hardware is spot on as it was fitted by Craigyb and ive eliminated that by testing with my old phone.
    Interested if anyone has had a similar problem with this phone or if anyone can offer any suggestions to try
    Simon
  2. The911SC
    The911SC Active Member
    1,032
    My HP Ipaq does this when not on charge. Try plugging the phone into a charger and see if it still happens.
  3. simonwjones
    simonwjones Member
    366
    cheers for that, still waiting for the cradle and car charger to arrive from SE
    will give it a shot then and report back
    thanks
    Simon
  4. s8craig
    1,754
    56
    Is the K800i in powersave mode for the BT?
    Craig
  5. Eeef
    Eeef Lord of War
    1,607
    I had the exact same issue with my W800 and my parrot bt kit. In the end I had to pair it in advanced mode, not sure if a similar option is availble on the RNS-E but have a look at the Parrot instructions here and see if you can map them to the RNS-E functionality
    http://www.parrot.biz/guide_chm/CK3X00/index.html
  6. simonwjones
    simonwjones Member
    366
    Thanks for the suggestions
    Craig power mode is already off for the bluetooth. Ive had my car charger arrive today but its made no difference
    beginning to thinlk I may have to wait for a firmware update. sent the info off to SE but not expecting much of a response
    Simon
  7. simonwjones
    simonwjones Member
    366
    spoke to both SE and Orange today, waste of space. Ive posted this question of Mobilereview.com's forum and a user there called bah434x reconns that he has the same setup and all works OK
    Anyone else have any ideas, even if its go back to my Nokia!!!!!!!!!!
    cheers
    Simon
  8. madvw
    madvw Active Member
    2,489
  9. simonwjones
    simonwjones Member
    366
    cheers for that but Im bang up to date firmware wise
    I'll keep trying
  10. simonwjones
    simonwjones Member
    366
    Finally fixed it
    the problem is when syncing contacts with outlook
    If the numbers are under Business, Home or Mobile it all works fine
    If any number are under the category "OTHER" thats where it screws up
    taken me days of trying but well worth it.
    It never dropped once whilst uploading the phone book
    the last test now is when I take the car out, but Im confident
    cheers
    Simon
