RNSE AMI Problems!
a6_chris May 23, 2013
  1. a6_chris
    a6_chris Well-Known Member
    1,883
    160
  2. s8craig
    1,750
    55
    Usually the harness is wrong, the L/R/GND are incorrect at the AMI end. There are differences between the RNS-E and the Concert/Symphony III B8 chassis AMI's, I think maybe you have got the right cable, but incorrectly wired.
    According to Elsawin
    Pin 21 RNS-E = Yellow = ground = 10 AMI
    Pin 22 RNS-E = Green = right = 9 AMI
    Pin 6 RNS-E = Grey = lef t= 4 AMI
    Check them on the AMI to the RNS-E 26 pin connector
  3. a6_chris
    1,883
    160
  4. a6_chris
    1,883
    160
  5. s8craig
    1,750
    55
    Neither, the Audio for the AMI connects from the 12 pin AMI connector straight through to the 26 pin connector (grey plug)
  6. a6_chris
    1,883
    160
  7. s8craig
    1,750
    55
    Sorry not 26 pin, the grey connector is 32 pin as shown in your picture. So referring back to original reply, check the 3 wires from the 32 pin grey connector to the 12 pin AMI plug. I included the wiring pins.
    Ignore the quadlock completely as it doesn't carry any audio for the AMI.
    a6_chris likes this.
  8. a6_chris
    1,883
    160
  9. a6_chris
    1,883
    160
  10. s8craig
    1,750
    55
    So you have the 3 wires of the 32 pin connector in the right places, what about at the other end, the 12 pin connector for the AMI, where do the brown, black and grey/white wires go to.
  11. elrao
    elrao Member
    378
    Just looking at this as I've got an AMI kit here to install this weekend.
    My AMI part number is 8P0 035 785 - so different to yours. Hope it will work!
    My lead has the same connectors you describe, while the cables aren't the colours mentioned above - i have the same black/brown/white - they do connect in the correct configuration :)
  12. a6_chris
    1,883
    160
  13. elrao
    elrao Member
    378
    Black one or grey one?
  14. a6_chris
    1,883
    160
  15. elrao
    elrao Member
    378
    I didn't take that one apart as I could see in to it to check which cable went to which pin.
  16. a6_chris
    1,883
    160
  17. elrao
    elrao Member
    378
    So you have
    Brown RNS-E pin 6 to AMI Pin 4
    Black RNS-E pin 21 to AMI Pin 10
    Grey RNS-E pin 22 to AMI Pin 9
    Compared to
    So looks like all the pins are connected in the right configuration, you just have different colour wires like me (Black for ground, instead of Yellow; Grey for Right, instead of Green; and Brown for Left, instead of Grey
  18. a6_chris
    1,883
    160
  19. elrao
    elrao Member
    378
    Could be a loose wire in the harness, coding etc still.
  20. a6_chris
    1,883
    160
  21. s8craig
    1,750
    55
    Can only be the AMI if the wiring is correct.
  22. a6_chris
    1,883
    160
  23. elrao
    elrao Member
    378
    I paid £260 (iirc) for a kit on eBay. Same guy i got the kit for my old S5 from. Just fitted (took ~ half an hour or so) and working fine with no fault codes (once I'd figured out the correct coding for my setup)
  24. a6_chris
    1,883
    160
  25. a6_chris
    1,883
    160
  26. elrao
    elrao Member
    378
    If the second one arrives, plugs in and works then at least you have proof it's the AMI unit.
    Hope you get them both sorted!
  27. a6_chris
    1,883
    160
  28. NHN
    29,328
    1,708
    Just fix the loom, grab some 009 wires from audi & replace the audio wires, 3 of them to the 32 pin connector.
    Question, not saying this will help as looks like wiring to me, but as this is free to test, did you try enabling & disabling the auxin coding in rns & ami as yet, to see if it made any difference?
  29. a6_chris
    1,883
    160
  30. a6_chris
    1,883
    160
  31. a6_chris
    1,883
    160
  32. a6_chris
    1,883
    160
