RNSE 193 LED MK2 - Retrofit Guide - With Pics :)
a6_chris May 11, 2013
  1. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    .. photobucket died, sorry.
    jimpa10 likes this.
  2. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    73
    Nice write up. Plenty of info so spot on there.
    Wish I had the bottle to just buy RNS-E.. Haha I'll defo use this guide if I get round to it.
    a6_chris likes this.
  3. wuta3
    wuta3 Well-Known Member
    1,124
    347
    Nice one!
    I really want one but they seem to come with a broken window on BOGOF.
  4. reepers
    reepers Member
    110
    15
    Again! Awesome write up! :D
  5. a6_chris
    1,883
    160
  6. Sidhu88
    Sidhu88 Active Member
    808
    76
    Just a bit of feedback about ur gps antenna installation. I'm pretty sure ur position is ok but just incase anyone has any problems or decides to try somewhere else, you will get bad signal if you mount the gps antenna under anything metal, main thing being the big beam that runs behind the dash. It really restricts signal, it's as good as putting the receiver inside a tin can. It's always best to have the magnetic part facing down too, some receivers only work one particular way up, others work any way up.
  7. a6_chris
    1,883
    160
  8. s3reptdi
    s3reptdi Member
    179
    I routed my antenna where my interior light is as I assumed the higher up the better? Not sure how I check for satellites but had not trouble so far, and I just let the magnet stick to the roof.
  9. Wicked666
    Wicked666 Active Member
    584
    35
    Great write up - i'm still paranoid about it being stolen so may wait until I change the car in the future to an S3 8V which has a retractable screen. If I ever decide to take the plunge, then will follow this guide.
  10. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    Great write up :)
  11. nluk100
    nluk100 Active Member
    947
    171
    43
    Great write up - do you have Bose fitted as I don't see any mention of the brown Bose wire needing to be relocated on the quadlock?
  12. jilm
    jilm New Member
    Hi looks excellent!! Thanks just used this one for my installation
    Do you have any like this guide on how to add SDS. not the flash of the RNS-e but the wirring of the RNS-e, bluetooth box, microphone. can you buy some finished wirring or can you make this your self. is there any coding afterwards..
    Br
    JILM
    AudiA3JJ likes this.
  13. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    I too would be interested in a guide for the SDS. I have been told for mine its just adding two wires as i already have the mic with my bluetooth, and then coding.
  14. MorkC68
    MorkC68 Stationary
    171
    27
    thanks for taking the time to post, its set me off thinking!
  15. nluk100
    947
    171
    43
    Put my GPS unit just above the headunit itself and get 6 satellites.
  16. Mindak
    Mindak Active Member
    799
    130
    43
    If I'm just swapping the old style sat nav for the new colour one will I just need to plug and play or still mess about removing glove box etc... Thanks
  17. wee_gus
    wee_gus New Member
    13
    Is there a way to run the aux in and the ami unit? I've plugged all mine in but my aux does not work now.
  18. Rob fisher
    Rob fisher New Member
    Hi, Ive just ordered a RNS-E to replace my standard concert fitted in my A3 2011 black edition, i plan on fitting myself as is does look fairly straight forward.... Just wondering about the coding vcds part.... Can i just buy the cable and plug into a laptop and do it from there or will i need more than this ie: software or anything.... Im unsure
    Many thanks
    Rob
  19. lgooch
    lgooch Well-Known Member VCDS Map User
    1,147
    153
    You need to buy vcds which is a cable and the software is a download. Contact NHN on here. Unless you know someone who can code it for you.
  20. Rob fisher
    Ok thanks, Ive sent NHN a message :)
  21. Jackx1
    Jackx1 Member
    126
    15
    I don't understand what the coding is for? Ive just fitted my MK2 RNSE and its perfect, functions 100%.
  22. Rob fisher
    Thats interesting jackx1 mine will hopefully arrive this week so will be fitting myself.... What model car did you fit yours into then?
  23. Jackx1
    Jackx1 Member
    126
    15
    Mine is a 2007, was literally plug and play. I put the GPS just above the unit and it picks up 6-7 satellites.
  24. lgooch
    1,147
    153
    all depends on what options are previously coded to your car beforehand. your sat nav may work, but you may still need to tell the car that you have it so that the directions in the DIS are displayed etc etc. NHN is your man.
  25. cboy
    cboy Member
    66
    any chance you can re-up the info for adding the sds wiring mate? i bought a kufatec with sds but it doesnt work
  26. RustyBucket
    RustyBucket Active Member
    347
    75
    Desperate for more info on the wiring for the mic, can you PDF your guide and upload :)
  27. cboy
    cboy Member
    66
    yes please :p
