RNS-E Sat Nav - Postcode & Audio
Agent_Trig Apr 3, 2011
  1. Agent_Trig
    Agent_Trig Member
    552
    Is there anyway of entering a postcode for your destination?
    I've looked in my PDF manual but it's an American manual with no mention to postcodes and I cant see any where to input a postcode into the sat nav.
    Also, I have noticed that the woman's voice comes from the passenger side door speaker - is this correct? Anyway of changing this?
  2. Dilligaf-UK
    Dilligaf-UK Chugging along VCDS Map User
    197
    In the space where you type the town name, it should also say Zip - that's Septic for postcode!
    It will only accept the first five characters or so, but it's better than a kick in the LoveSpuds
  3. N8
    17,163
    719
    First part of the postcode, then road name.
  4. Agent_Trig
    Agent_Trig Member
    552
    Cheers dudes
  5. Agent_Trig
    Agent_Trig Member
    552
    Does anyone know if the voice issue I mentioned above is normal or not?
  6. Adam.
    Adam. Meow.
    662
    34
    Stab in the dark but is the balance settings for the audio on satnav centered right?
  7. Agent_Trig
    Agent_Trig Member
    552
    I thought that the balance settings on the RNS-E were global across all sources? Is this not the case then?
  8. kite
    kite Member VCDS Map User
    677
    the unit can be coded to have the nav voice from the drivers door.
  9. Agent_Trig
    Agent_Trig Member
    552
    How do I go about doing this?
  10. kite
    677
    From the Rosstech wiki
    Channel 136: Driver Position
    • RNS-E Basic
      • 03226 = Left-Hand-Drive (LHD)
      • 02632 = Right-Hand-Drive (RHD)
    • RNS-E High/US
      • 00005 = Left-Hand-Drive (LHD)
      • 00013 = Right-Hand-Drive (RHD)
