RNS-E S/W Upgrade question - New to the Forum
dmistry21 Mar 28, 2012
  1. dmistry21
    dmistry21 New Member
    I have an Audi 3.0 Quattro (54 reg) with an RNS-E headunit and need to know what I need to buy.
    I've sort of got an idea from some of the posts on here. The S/W Version is 0550, HW is H99 and Map is M1N061018_EN0603 (Understand that the maps have nothing to do with the s/w upgrade). What I need to know is:
    1. What S/W version can I upgrade to (i.e Can I go straight to the latest S/W version or is there an upgrade path ?)
    2. I also want to enable the aux port so I can use a 3.5mm Jack on an iphone and is there any coding required (Not sure if 0550 lets you do this ?)
    3. Is updating the software simple as putting the DVD Rom in the drive and letting it run ?
    Many Thanks
  2. s8craig
    1,753
    55
    SW 650 is the highest and will never be superceded on the MK1 RNS-E.
    Enabling the AUX port can be done with VCDS, so yes coding is required
    Yes, simply insert the latest DVD and let it run through updating twice.
  3. dmistry21
  4. NHN
    29,352
    1,720
    Not entirely true as the fw is stored on the map dvd, unless you've downloaded the fw from another source.
  5. dmistry21
    Didn't know that. So i'm guessing I can upgrade the S/W via a CD-R or a new Map DVD ?
  6. s8craig
    1,753
    55
  7. dmistry21
    Excellent, So just to confirm I will need the 0650 software to enable the aux port as 0550 doesn't have support ?
  8. dmistry21
    Just ordered it [​IMG] Next step figure out how to fit it but cross that bridge when I get there...
    I'll attempt the VCDS programming with the 0550 S/W first and see how I get on.
    Thanks for the advice.
  9. az786
    az786 New Member
    20
    Hi dont wanna hijack the thread but will a rnse disc from a 2011 model car work on our rnse satnavs 2005 model cars?
  10. s8craig
    1,753
    55
    Yes it will
