RNS-e Retrofit Procedure
stevereid Jan 19, 2011
  1. stevereid
    stevereid Member
    254
    Ok, I think i'm juat about at the point of being able to start my retro fit.
    I'm sure this has been asked and covered before..but.. has anyone produced a step by step procedure for replacing the single din cage with a double din..trimming the CC unit etc etc ?
    I would appreciate all your help.
    Steve
  2. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,995
    217
    PDF on it's way.
  3. Cabbyfan
    Cabbyfan Active Member
    840
    34
    I retrofitted RNS-E into my last B6 saloon, took 6 hours mainly to swap the single DIN to a double Din. I cheated though and bought a new climate module on EBay and sold my old one after the install. Its not actually that difficult, just takes time. Even my local Audi dealer said they couldnt tell it had been retro-fitted unless they looked very closely, worst but was trimming down the centre console / ashtray plastic from memory.
  4. stevereid
    stevereid Member
    254
    Thanks for that.
    What needs done with Vag-com once the RNS-e is fitted ? Just I don't have Vag-Com and the RNS-e is on its way :)
  5. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    It's all here - silly to repeat what has already been covered previously very well!
    And all coding and adaption information can be found here at the Ross-Tech site.
