RNS-E Retrofit Cable Assistance
lococard Jun 14, 2014
  1. lococard
    lococard New Member
    Hi Guys,
    I've retro fitted an RNS-E into my A4 B6 with a double din conversion. However, it appears my RNS-E is actually draining the battery, and i believe it is because I've got the wrong cable.
    I have an RNS-E, 6 stacker CD Changer in glovebox and non-bose.
    - http://www.ebay.com.au/itm/Audi-A3-A...ebdb09a&_uhb=1
    - "1x ISO CD-changer, BOSE plug"
    This is what the seller has described the item as.
    Should I be searching for a NON-Bose with CD changer? Could anyone advise which cable?
    Thanks,
  2. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,301
    390
    Probably get a better response in the ICE->SatNav forum
  3. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,698
    642
    I take it you have coded the unit correctly?
    The cable in the ebay add shows the brown ISO connector for the front speakers, true Bose adapter cables should not have this connector.
  4. lococard
    lococard New Member
    Yea I belive so. Used a VAG COM cable and changed a digit to reflect the newly installed RNS-E.
  5. B5NUT
    3,698
    642
    OK, so what is the coding on the RNS-E
  6. lococard
    lococard New Member
    Do you mean what was changed using the VAG COM cable?
    I'll have to look into it but from what I can recall all that was necessary was updating one of the stereo codes so that the ECU knew an RNS-E was fitted. Only one number had to change.
  7. B5NUT
    3,698
    642
    Yes. You should have coded the RNS-E and the instrument cluster, and bluetooth module if fitted.
  8. lococard
    lococard New Member
    It doesn't have BT.
    Would not programming the instrument cluster affect the power drain?
  9. lococard
    lococard New Member
    I've reprogrammed the codes.
    STG 56 (Navigation) = 03?1153
    STD 17 (Inst Cluster) = 00005
    Does that look correct?
  10. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
  11. lococard
    lococard New Member
    Thanks for the reply.
    This is correct apart from the TV tuner, so may need to update that. I only need to change the last code then right?
    = 0301152
  12. lococard
    lococard New Member
    Ah right, my trial version of VCDS lite won't let me check that.
    I've pulled the fuse for the radio and see if the battery drains over night.
  13. PetrolDave
    1,559
    85
    That's why you need the full version of VCDS...
    If the RNS-E is coded for the correct vehicle and the CAN bus is connected properly then it will turn on/off with ignition OK.
    I say ignition but that's actually a simplification - the RNS-E turns on, but with a blank screen, when you unlock the car; then the screen turns on when you turn the ignition on. When you turn the ignition off (and remove the key) the reverse happens, i.e. the RNS-E stays on but with a blank screen; it only turns off when you lock the car or 30 minutes after you remove the key.
  14. lococard
    lococard New Member
    I see, I'll try sourcing a full version.
    However, I pulled the fuse for the 'Radio' and left the car overnight. The RNS-E wouldn't turn on, so I believe the correct fuse was removed.
    But in the morning the battery was flat...
    Would they mean it may not be the radio then :S
  15. PetrolDave
    1,559
    85
    If the radio fuse was removed and the battery still went flat then it can't be due to the radio...
  16. lococard
    lococard New Member
    Yeah, looks like its time for a new battery. However I believe the RNS-E has killed it.
    Last night I left the positive terminal to the battery unhooked, in the morning the battery was flat.
    However, when I connected the terminal in the morning. The radio came on.
    Should the radio work with no key in the ignition? The RNS-E was on and playing music :S
  17. PetrolDave
    1,559
    85
    Yes, you can turn the RNS-E on at any time - but it will turn off after 30 minutes unless you turn the ignition on in the meantime.
    It has only PERMANENT 12V and uses CAN bus messages to tell it when to turn on/off.
