RNS-E Problems - Disk Drive Load/Eject Malfunction
C17LJR
Member
Hi Guys,
Recently fitted an RNS-E as well as an OEM Bluetooth unit, all was well until i tried to use the sat nav (disc was sent after the unit so was testing that)
Basically, the unit isn't loading or ejecting any dvds/cds. originally thought it was the the load/eject settings on channel 67, it is however set to 0 so should work fine. if only it was that though!
So this is the fault...
02444 - Disk Drive Load / Eject Malfunction
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 241
Time Indication: 0
Date: 2011.04.04
Time: 20:54:32
Do I need a new drive? Anyway to fix this?
Thanks in advance, Carl
Try a CD lens cleaner.
I have seen a post somewhere that included pix of a laser change... might be worth a google
problem is, the drive isn't loading/pulling the disc into the unit?
Rosstech wiki shows a reset
Channel 111: Reset
  • To perform a system reset/restart save 1 as new value.
I recently had the same problem, took the unit out of the car, took the top plate off and found that my disc had got stuck above the drive mechanism once i removed from the back and then tinkered with it pushing it back in as i was hitting the eject button it went in and under with no problems, just need a new disc as mine was badly scratched!
9
4K
NHN
3K
NHN
