Rns-e not picking up satelittes
rob irl tdi Oct 15, 2011
  1. rob irl tdi
    rob irl tdi Member
    240
    My rns-e is picking up 2 then going to zero satelittes. Do i need a new aerial or has it just fallen out
    I retrofitted it last October
  2. kite
    kite Member VCDS Map User
    677
    check to see if its a loose connection, then buy a new antenna....
  3. NHN
    29,353
    1,720
    1st of all, where did you mount it?
    If behind the cluster or rns, thats never a location I use for this very reason, stick it above the glovebox next to the passenger side vent with 2 layers of good double sided padded tape, never failed.
  4. Rolling Thunder
    Rolling Thunder New Member
    NHN...
    I have a similar problem but have not fitted a separate antenna... do you have any particular recommendation or will any external antenna fit?
    Many thanks
  5. gary3306
    gary3306 Active Member VCDS Map User
    989
    41
    The Mk2 I've just fitted to mine isn't picking up any satellites. When I received it, i quickly pulled the concert out of the dash and plugged in the RNS-e and everything burst into life, including it picking up 3 satellites and it finding me on my drive outside my house within a couple of seconds. All good.
    Since fitting it, there is nothing on the sat nav side of things, no satellites and VCDS reporting 'Antenna for navigation open circuit'.
    So flamin' annoying. Waiting for a new antenna to come now and praying that its that thats at fault and not the unit.
  6. NHN
    29,353
    1,720
    I always offer a sharkfin as an install option given the quality of the gps squares are few & far between, some work fine, some are just plain ****, only sure fire way I know to get the best signal is to fit a sharkfin, I've done numerous & always work very well.
    Check the gps connector on the rns to see if somethings amiss, take the lid of & check the coax internally to see if thats somehow faulty.
  7. hades-
    9,481
    646
    how much to fit the fin ?
  8. NHN
    29,353
    1,720
    On an 8P I charge £175 supply/fit of oem sharkfin.
  9. Rolling Thunder
    Sorry I should have said that I have an A4 cabriolet - Logically a sharkfin needs to have line of sight to the satellites which is fine for a coupe. Any options for a topless car :)
  10. hades-
    9,481
    646
    A4 B7
  11. NHN
    29,353
    1,720
    Stick it on boot lid I guess, but would have to check the internal structure of the lid itself to see if there's any cross members to negotiate.
  12. gary3306
    989
    41
    Yea I've done that Nige. Tiny pin in the middle is nice and straight, and I whipped the top off and the little cable from the connector looks fine. Thats why I'm hoping that the antenna is faulty. It looked a bit of a cheap affair to be honest. The sharksfin may be a path I'll take
    Think I've just had an idea for what Mrs gary3306 can get me for Christmas :)
