RNS-E mk1 vs mk2 ?
its_neil Aug 1, 2011
  1. its_neil
    its_neil Member
    62
    Am currently debating getting the RNS-E retrofitted but am curious to the actual differences between the older and newer RNS-E units.
    I know the screen is higher quality, the unit has SDHC support and a faster processor but does anyone have any pictures of the screen quality between the mk1 and mk2 units?
  2. HIGGINS
    HIGGINS Member
    528
    15
    Pictures arnt the best buddy go to your nearest audi dealer and have a play with both of them :) Then you can see yourself whats the difference haha
  3. paddy
    paddy Audi=we just sell em mate, we can't fix em.. Team Ibis Audi S3 Black Edition DSG
    5,399
    224
    I think i depends on your budget and what you want to do. If you just want to follow a map then Mk1 is fine, if you want 2x32mb SD cards and watch TV then a MK2 is a must. Really down to looking at both because only you can decide and i doubt pictures on here would really convey the different screen res TBH.
  4. NHN
    29,593
    1,782
    If you can afford it, MK2 unit every day of the week, screen alone makes it worthwhile for nav lol, but the 32GB sdhc is good aswell, 64gb of tunes is a hell of allot & would never run out of tunes.
  5. gary3306
    gary3306 Active Member
    989
    41
    What are we talking pennies wise for a Mk2?
  6. Yaks
    Yaks Member
    181
    Anywhere from about £500-£600 off eBay ( from Lithuania, fitting and coding yourself ) to I believe around £2,500 if you walk into an Audi garage !!
    I paid £800 for a factory refurbished unit, fully supplied and fitted in Bradford. Seems to have the latest maps ( ie some fairly new roads are on it ).
  7. S3RYE
    S3RYE Interior Next!!
    3,448
    71
    i need to get me one of these new Mk2 flashy units... Mk1's are prehistoric.. Its so slow, Basic, sh1t resolution, cant see Ipod tracks, take 5 minutes to load routes, and tells you to to things like "turn SLIGHTLY left off the roundabout"
    basically, if you are considering upgrading to RNSe make sure its a Mk2!!!!!!!
  8. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    606
    rye there is on mk2 black surround on ebay for £400 pick up only will get the link just now
  9. Lima
    Lima AUSmotive.com
    396
    29
    Agreed. The screen res is much, much nicer. I didn't think too much of it at first, but comparing my screen to an older unit makes the decision easy IMO.
    As noted photos aren't the best, but here's a couple I have stored away...
  10. ern
    ern Member
    97
    Did i read someone say theres TV on it?! Is this built into the Sat Nav aerial?
  11. paddy
    5,399
    224
    Pop out the DVD and it will tell you what year the maps are.
  12. wez3570
    wez3570 Member
    704
    20
    Remember you'll need an AMI retrofit to see iPod tracks!
  13. S3RYE
    3,448
    71
    I'll do whatever it takes. I'll speak to Nigel :beerchug:
  14. wez3570
    wez3570 Member
    704
    20
    I wanted it done also, but £700-£800+ to see iPod tracks?
    Can't justify it myself. I'll stick with SD cards thank you. Lol
  15. paultaylor
    paultaylor Member
    294
    does anyone know if the black piano surround is purely a cosmetic change or means a more up to date spec?
    And will any Rns e with a media button be much better than a Mk1?
  16. Agent_Trig
    Agent_Trig Member
    552
    RNS-E MKII (with media button) is much better than MK1. I know as I upgraded from MKI to MKII myself.
    As far as I know, the piano black surround is purely cosmetic.
  17. NHN
    29,593
    1,782
    Cosmetic
  18. ryanstewart9
    ryanstewart9 Member
    494
    I've heard there is an Alpine unit that allows you to use your iPod with your RNS-E?
    Alpine�-�iPod Interface�-�KCE-425i
  19. cloughy
    cloughy Member
    515
  20. wesley
    wesley Giac Extreme+!! Lovin it
    350
    23
    Does anybody find on there mk2 rnse that when you use the steering wheel controls to change tracks there is a long delay in the screen changing tracks?? The actual song changes instantly just the screen doesnt change instantly!!
  21. NHN
    29,593
    1,782
    Yes also found this, think its also down to the sd card in use tbh.
  22. MattyW19
    MattyW19 Member
    401
    I'm thinking of doing this.. Just a couple of questions - Is it basically plug and play? Why is coding needed?
  23. NHN
    29,593
    1,782
    Coding is always advisable as it may be a blank canvas as such & thus it wont shut down with ignition & certain features may not work.
  24. wesley
    350
    23
    I bought class 10 SD cards too thinking that would speed things up!!
  25. NHN
    29,593
    1,782
    Is it running 0150 or 0200 FW mate?
  26. MattyW19
    MattyW19 Member
    401
    Thank you for your reply! Oh ok I understand, so it's basically when the ignition is turned off the unit stays on? Would the RNSE turn off after an hour too or?
    Does coding void warrenty?
  27. wesley
    350
    23
    0200 mate.
  28. paultaylor
    paultaylor Member
    294
    Can iTunes library mp3 files be put on the SD cards and then they come up on the display and have an iTunes "look"?
  29. cloughy
    cloughy Member
    515
    I was very fortunate that my RNS-E didn't need any coding and was plug and play, best thing I've ever bought for my car! glad I went OEM
  30. cloughy
    cloughy Member
    515
    No unfortunately not, well not straight away. iTunes is stored in a different format (AAC) however you can convert iTunes AAC into MP3 which you can then use on the SD card
  31. paultaylor
    paultaylor Member
    294
    all my iTunes is mp3 or m4v haven't used AAC in years so when I finally get a Rns E I can just drag files to album folders on the SD cards.
    Does anyone play mp4 or video files off SD cards? tv in motion would have to be disabled I'd imagine
  32. Jonny-Smith
    Jonny-Smith Member
    57
    Is there a certain type of sd card you need. I think I was reading somewhere that the sdhc don't work. Sorry If I've quoted that wrong. I'm looking to get an sd card for mine. Where's the best place to get one?
  33. cloughy
    cloughy Member
    515
    Actually having looked most if not all my iTunes is mp4, I'll have a go at sticking it on the SDHC card and see if it works
  34. cloughy
    cloughy Member
    515
    MK1 RNS-E has 2 x 2gb slots the latest unit supports 2 x 32gb SDHC
    If you have a MK2 unit go for SDHC, they are much quicker
    Best places to go are mymemory.co.uk or play.com, class 10 cards are very quick
  35. NHN
    29,593
    1,782
    MP3 only.
  36. gary3306
    989
    41
    As nige has just said, you'll have to convert the itunes mp4's to mp3. But you're not alone mate lol, I bought two 16gig cards, loaded all my itunes stuff on and wondered why my RNS-e said no recognised files (or words to that effect). Was only when I plugged the card back into my computers card reader that it dawned on me.
  37. cloughy
    cloughy Member
    515
    cheers fellas, saves me mucking around with mp4!
  38. gary3306
    989
    41
    Slightly different for me. I've found that sometimes it takes a good few seconds (up to 10) to change songs. I've skipped songs unintentionally as I've thought that the scroll wheel movement hasn't registered so I've had another go. If I use the selector on the unit however, its instant. Bit annoying but I'll live with it.
  39. wez3570
    wez3570 Member
    704
    20
    Mk1 is 2x 4gb max
    RNS-E Compatable 4GB SD Card Non HC | eBay
  40. Tuomas
    Tuomas New Member
    Just installed my 2011 RNS-E and it was also pulg&play, no coding or any other problems. Extremely happy with it!
