rns-e loudness - how can iturn it off?
dunk Nov 28, 2008
  1. dunk
    dunk Member
    770
    i know it can be turned off temporarily in engineering mode, but its always back on by default each time i start the car or restart the rns-e, and i know that most of the other options in the audi part 3 bit of engineering mode are changeable with coding or settings, but i would like to permanently disable the 'loudness' function
    anyone know if/how this can be done?
  2. royjk
    royjk Member
    167
    Just turn the volume for the navigation down as low as it will go in sound set up.
  3. dunk
    dunk Member
    770
    turning the navigation volume turns off the 'loudness' function?? sounds very odd worth a try, thanks
  4. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    What loudness function??
  5. dunk
    dunk Member
    770
    when the volume is low, the 'loudness' function turns up the bass and trebble, and this effect is gradually reduced as the volume goes up - its supposed to compensate for the ears poorer sensitivity to bass/trebble at low volumes
    unfortunately it seems to be only accessible from engineering mode and temporarily disableable - and turning the sat volume down does not switch it off
  6. Staz
    6,206
    67
    I haven't noticed a thing!
