RNS-E, Kufatec AMI with a Rhapsody HDD Media Player - Anyone fitted this?
BigRD Mar 16, 2008
  1. BigRD
    BigRD Member
    59
    Hi folks,
    I'll be picking up my A4 B7 in a couple of weeks and after a few hours of searching I came across a post over at http://www.rs246.com/index.php?name=PNphpBB2&file=viewtopic&t=61892&postdays=0&postorder=asc
    This gives details of an RNS-E using a Kufatec AMI with a Rhapsody HDD Media Player controlled via the RNS/MFSW controls. This would put my complete music collection on a hard drive in the car with a selection of films. Anyone fitted this or something similar?
  2. s8craig
    1,759
    56
    Fitted these plenty of times, but you mean IMA, not AMI.
  3. BigRD
    BigRD Member
    59
    You are, of course, correct. Typo :yes:
    Which of the Rhapsody players do you find operate best with the RNS-E controls? There appears to be some debate on the 110 and 300 not working properly although they are listed in the latest compatability list. Have you been able to source the RSH-250? It looks nice and compact for fitting in the glove box.
    Also where do you take the power supply from?
  4. s8craig
    1,759
    56
    I have used the 100's and 300's. I Prefer the 100's as they have a better audio stage (louder) than the 300, the 110 is also OK.
    I have no experience of the 250.
    As for power, well you need a switched live from the fuse box.
  5. BigRD
    BigRD Member
    59
    Cheers for the info. Do you find the 110 works fine from the RNS-E? It's the most easily available player in the UK.
    Audi's are new to me so I've a steep learning curve to achieve with regards to the electrics. I'm an electrical engineer and a dab hand with PC's so none of this should be above my capabilities. Can you point me in the right direction as to ignition switched power?
  6. beerglass
    beerglass Member
    234
    Hi
    Looking a doing the same.
    Do you need to enable VIM first ?
  7. BigRD
    BigRD Member
    59
    You only need to enable VIM if you want to be able to see the Rhapsody display whilst driving. This is my prefered choice. My IMA cable has arrived so I just need to buy the rhapsody.
