RNS-E iPod Random Feature - Not Static after ignition off.
garethrees Jan 5, 2013
  1. garethrees
    garethrees Member
    44
    Hello, I've done a search but not managed to find a thread on this so please point me in the right direction if it's been covered.
    I've got a RNS-E with the AMI iPod interface and everything works great apart from the Random order "Mix" setting which I have to manually select at the start of every trip.
    Basically if you select a play list, then select "Mix" to get random playing of tracks when you stop turn the ignition off and re-start the "Mix" is no longer selected.
    Is there any way to keep "Mix" on? a firmware update or something?
    Regards Gareth
  2. NHN
    29,351
    1,720
    What FW is currently on the rns-e, goto the car screen & show pic of that screen, as there's an fw update on latest dvd's, but thats not to say that will fix this issue.
  3. garethrees
    garethrees Member
    44
    Thanks again,
    SW: 0070
    HW: H02
    MAP: 8P0919884_AJ_EUW
  4. NHN
    29,351
    1,720
    Damn thats an old dvd & firmware, newest has 0220 fw & BE DVD.
  5. garethrees
    garethrees Member
    44
    Ok, just got the 2013 DVD and inserted it, now reading:
    SW: 0070
    HW: H02
    MAP: 8P0919884_BK_EU1
    The maps are updated but it did not auto update the firmware to 0220, anyone know if you can force it?
  6. NHN
    29,351
    1,720
    Yeah would need to goto into rns adaptation channel & enable the software upgrade option.
  7. s8craig
    1,753
    55
    Regardless of the adaptation channel if the RNS-E sees a disk with a higher index it should update to the latest SW.
  8. garethrees
    garethrees Member
    44
    Tried Various Disks and now managed to get:-
    SW: 0200
    HW: H02
    Car went for a service this week and I asked Audi to update the software, they did not understand what I was talking about, so I explained a few different ways. The end result "we cannot update the software sir".
    Not 100% sure that is correct, so can anyone point me at the version of the firmware on each of the CDs so that I can simply purchase the latest one to get to 0220.
    Lastly does anyone else notice the "Mix" option is not static i.e. if you Select iPOD Mix for tracks you have to select it for every journey it does not stay on after you turn the engine off and back on again.
    Regards Gareth
  9. NHN
    29,351
    1,720
    Its a fair standard reply by them, as sometimes updating firmware & still using an older dvd, will not allow the system to work, in your scenario it should be fine, but they probably just don't need the hassle should things go wrong, so kind of infuses you to buy the newer dvd which will update fine & work without any such issues.
  10. phil_w
    phil_w Active Member VCDS Map User Audi A4 Audi Avant Owner Group S-line owners group Team Brill Red
    602
    57
    Same for me on latest rns-e firmware. Same thing happened to me on basic IPod interface with concert II+ in previous A3 - my old 56 plate A3 with single din concert II always remembered the random setting so I suppose we a a victim of progress...
  11. garethrees
    garethrees Member
    44
    Thanks Both, finally got 0220 Firmware installed, no change same fault.
    I did raise an enhancement request to Audi a few months back, they passed it on to the engineers if anyone else wants to raise the same request and add a comment here are the contact details I used:-
    Craig Westwood
    Customer Relations Manager
    Digital Communications
    Audi UK Executive Office
    T 01908 601 733
    E craig.westwood@audi.co.uk
