RNS-E IPOD ADAPTER HELP
antonio87 Feb 17, 2009
  1. antonio87
    antonio87 Member
    51
    just got an original ipod adapter for the rns-e (8E0051444A) tryed to install it this afternoon but had no luck. the instructions make no sense to me and have no idea how to set it up.
    anyone installed one on their rns-e any tips?
    any kind of help much appreciated
  2. JohnS3
    JohnS3 Active Member
    3,032
    It plugs into the CD changer port in the loom, or replaces your existing CD changer if you have one. If you have an 07 car or later then it should plug into the quadlock, if it's an earlier car you should have mini ISO plugs to deal with. It's very simple to operate, pressing CD number 1 to 5 on the headunit gives you the first 5 alphabetical playlist, CD6 gives you every track on your iPod.
  3. Nelson_R32
    Nelson_R32 Member
    305
    You've got the wrong kit. You need 8E0051444B for Quadlock Connector Radios.
  4. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    If it has a 'flying' ground lead these normally have to be connected to the radio chassis too.
  5. antonio87
    antonio87 Member
    51
    thanks for that guys. i spent so long on it just looking at it and trying to make sense of it. ill have to take it back to audi and get it changed. thanks again
  6. amcg1
    amcg1 New Member
    10
    quick question as im trying to fit my ipod kit, how did you guys remove the brown coloured wire from the original quadlock adapter so that you can replace it with the brown fly lead that is on the ipod cable as i cant seem to be able to remove mine
