rns e install!
syk919 Nov 27, 2012
  1. syk919
    syk919 Member VCDS Map User
    66
    im ready for my first major install (rns-e + bluetooth) i know im gonna struggle on a couple of things
    1. dragging the gps wire from the boot to the front(voice guided sat nav)
    2. trimming the climate control unit
    3.getting the bluetooth module under the seat
    4. coding everything to make sure it works
    i got in touch with nigel but he hasnt replied for like a week although he was recovering from a virus?
    if anyone else can fit everything for me please send me a pm thanks
  2. JamesS4cab
    JamesS4cab Well-Known Member
    1,189
    94
    Questions:
    1) Why do you need to run wires from the boot for the nav??
    2) Trimming the climate control - why??
    3) Its not essential to put it under the seat - just preferable.
  3. fangio
    fangio Well-Known Member
    1,466
    172
    Are you changing from single din? If not, no need to trim the c/c unit. GPS aerial works perfectly on top of glove box.
  4. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Sorry to hijack, is there a list of things needed to add an rns e to a car?
  5. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,118
    9,125
  6. Sandra
    26,118
    9,125
    Hi, Nigel is back on his feet again, just drop him another pm and im sure he will get back to you. :) x
  7. NHN
    29,300
    1,702
    Replied last week mate, didnt get answer as yet, just sent you another PM :)
  8. syk919
    66
    ok just to clear a couple of points.
    1.im coming from a single din so yes i do need to trim the unit unless i can get hold of the double din version
    2.i have voice guided sat nav...so its logicak that the system will use gps?? i also have the shark fin installed? the audi sat nav drive is in the boot my guess is that the gps aerial is connected to the drive? correct me if im wrong
    3.i want to keep everything OEM so i would prefer to put bluetooth under the seat. also i have so many plug and play connections there would be no space behind the rns-e and ive read there is no space to put above the glove box.
    and il pm you now mate
  9. syk919
    66
    mike you will need the following if you have a single din car with a concert radio.
    if not you will most likely need very few items
    1. single din car with concert no bose.
    *rns-e up to you which version you get
    *adaptor the quadlock one search for it on ebay
    *keys to remove the radio.again ebay or amazon or audi if your feeling generous
    *diversity antenna
    *gps antenna if you dont have it installed ebay again very cheap
    *audi sat nav dvd.usually come with the rns-e
    *double din climate unit if you dont feel like trimming your old one
    2.double din with symphony
    *rns-e+ sat nav dvd
    *gps antenna
    *radio removal keys
    you will need to get it coded. if you have a double din already you will need very few extras depending on the age of car possibly? maybe the older double din radios may need harness adaptors? if you put a pic up of the system im sure nhn or someone else will tell you exactly what you need
  10. Jay.Ing
    Jay.Ing Active Member Team Ibis Bronze Supporter Audi A3 Black Edition TDi
    344
    58
    Which Drive have you got in the boot? All my RNS-E equipment is in a single unit in the dash?
  11. syk919
    66
    i have the sat nav drive in the boot. which holds the sat nav cd. i control the sat nav from near the handbreak and i get voice guidance along with dis info to help
  12. Mikemc
    1,024
    37
  13. Mikemc
    1,024
    37
    I don't think mine is a quad lock either, ill take some pics later
  14. mike foster
    3,967
    Concert is single din and does not have quadlock !
  15. Mikemc
    1,024
    37
    If quad lock is the one with a lever on it then I don't have it, although ill double check it once my cars out the garage
  16. mike foster
    3,967
    Quadlock has a lever on it, is square and contains 4 (quad ! ) separate plugs.
  17. Mikemc
    1,024
    37
    Yea I took one out a family members fiesta, I'm 95% sure it was about 3-4 separate plugs, is this not normal then? I also seem to be missing a cd changer from the glove box if this helps as there's just a plug in the top right hand quarter
  18. mike foster
    3,967
    Mike, you will need all the items listed in '1' in post #13. The concert radio has separate inputs and a quadlock adapter is required as the rnse only accepts quadlock..
    It would appear that your cd changer has been removed by a previous owner !
  19. Mikemc
    1,024
    37
    Haha yea, not like I would use the changer, is there an iPod cable I could plug into it instead?
    And do you roughly know the prices of the items needed
  20. audicruiser
    audicruiser Audi Heaven
    1,865
    All that will redundant then with RNS-e so no need to run wires from the rear to the front of the car.
  21. syk919
    66
    yea NHN has let me know of that. all i really want to do is use the existing gps wire to be honest.
