RNS E ice install
Triple.O.G Jul 1, 2010
  1. Triple.O.G
    Triple.O.G Active Member
    1,113
    Ok ill ask again, I have the sat nav dvd i my 07 A4 which i believe is an RNS E??
    Can i wire up a sub and amp to that or do i need to replace the headunit.
    Anyone? cos I didn't get an answer last time.
  2. BigAardvaark
    BigAardvaark Active Member Team Scuba Audi A4
    138
    35
    You'll be able to pick up RCA line outs using a simple quadlock adapter on the back of the RNS-E. The world's your oyster then.
  3. AndyMac
    9,832
    45
    You should be able to pick up the feeds from the rear amp as the rear pre-outs run from the HU to the amp along with the remote turn on feed. All you'll need to do is run power from the battery.
  4. Triple.O.G
    1,113
    Brilliant, I have my sub, amp and wiring kit on it's way for stage 1 then will be adding front components and possibly a power cap and another amp.
    I didn't realise the current amp was in the boot?
    Also once front components are in do I just leave the standard rear speakers or disconnect them?
  5. BigAardvaark
    138
    35
    Leave the cap in the shop, useless. If you have some quality gear, leaving the rear speakers connected would just mess things up image wise. But do make things louder.
