RNS-E. how does the SD card fit?
RU55SSO Aug 20, 2011
  1. RU55SSO
    RU55SSO Member
    792
    24
    This might sound like a silly question but how does the sd card fit into the RNS e unit. Behind the screen the two sd slots are there but the sd card just does not go in?
  2. Adam.
    Adam. Meow.
    662
    34
    It should just slide in.
    You sure you're putting it in the right way?
  3. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,766
    356
    You sure it's the right kind? Is there already a card in maybe?
  4. RU55SSO
    RU55SSO Member
    792
    24
    Tried both ways there seems to be a metal bit blocking acces to the width of the card
  5. RU55SSO
    RU55SSO Member
    792
    24
    Do they only accept 2gb cards this is a 4gb ultra
  6. N8
    17,163
    720
    It's like making love to a woman, only one way it can go in :laugh:
  7. audigex
    audigex Active Member
    600
    46
    N8, you might need a new woman - yours sounds faulty.
    Russo, SD cards are the same size and shape regardless of capacity - they should all go in the slot the same: if the device isn't compatible it just won't work once it's there.
    Can you take a photo? It sounds like there's a blanking board across the slot :s
  8. sparki
    sparki I <3 bass
    328
    10
    In its best mate while its sleeping?
  9. MartayMcFly
    2,766
    356
    Yup, 2GB each. Didn't know they'd be a different size/shape for a 4GB though.
  10. RU55SSO
    RU55SSO Member
    792
    24
    No the cards are the same size.
    You are correct it does look like there is a blanking board across the slots
  11. Adam.
    Adam. Meow.
    662
    34
    Looks to me like the face has been taken off and not put back on properly so the slots aint lining up.
  12. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    I think Adam is right, whether is SD or SDHC card they use same format so should slide in nicely. Looks like a screwdriver job for me:]
  13. RU55SSO
    RU55SSO Member
    792
    24
    well in that case i will be leaving it until audi swap it out for the 2011 nab unit i ordered
  14. LWNY
    LWNY Member
    161
    You can use 4GB card, but it cannot say SDHC.
  15. quattro81
    quattro81 All the gear.. No idea
    970
    90
    How much is that costing from Audi if you don't mind me asking mate?
  16. Vertigo1
    Vertigo1 Well-Known Member Team Navarra Audi S3
    3,794
    864
    These are rarer than hen's teeth btw. 4GB was never a proper standard for SD cards and very few were made as SDHC took over. They do work if you can find them though :)
  17. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    In the next few weeks I will have 3x 4Gb SD Cards (non HC) for sale when new car comes. So they will appear in classifieds shortly.
  18. N8
    17,163
    720
    You lot gimme jokes :laugh:
  19. RU55SSO
    RU55SSO Member
    792
    24
    Im getting it for 650 seeing as they wanted me to buy an s3 so bad and it was the one option i wanted in a car,
  20. S-Line_Wales
    S-Line_Wales Member
    128
    Are these still available ? if they are give me a shout, as Ive just discovered one of my 4gb Transcend cards has gone belly up and refuses to accept that write protection is off ! Still works in RNS-E but I cant add or remove anything from the card, so need some new ones asap !!
