RNS-E Help.... (Navigation Voice)
cliveywolves Jan 24, 2007
  1. cliveywolves
    cliveywolves Member
    229
    Hi all....
    Just upgraded my software on my rns-e to EU SW 0500, all went perfect no problems, but while navigating this morning i noticed that the navigation voice instructions were only coming through one rear speaker on the passenger side is the normal ???
    Im sure (but could of be wrong) on my previous software EU SW 0100 it came through all the speakers ????
    Just bugging me .... [​IMG]
  2. benw123
    benw123 Moderator
    1,863
    Mine only comes through the passenger side speaker. I thought I was going mad as well, but my wife also confirmed it.
    Not sure why this is the case, but it seems to be by design. Perhaps it's to help the driver imagine their passenger is providing the instructions! :)
  3. cliveywolves
    cliveywolves Member
    229
    Ha Ha.... I know i though id gone deaf this morning in one ear....
    Looks like you got the same issue as me it is supposed to come out of the right hand side speaker... But looks like our RNS-E's Are coded for LHD Cars... Never Mind think i can live with that issue.....
  4. benw123
    benw123 Moderator
    1,863
    Could be a question for the American users on navplus. The RNS-E would know whether its fitted to an LHD or RHD car (via the CAN) and so could adjust its voice output accordingly.
  5. gizze
    gizze Member
    645
    Needs to be coded...
    Channel 136: Driver Position
    5 = Left-Hand-Drive (LHD)
    13 = Right-Hand-Drive (RHD)
  6. gizze
    gizze Member
    645
    Also, if you have the voice coming out of the rear I would guess you don't have bose, and you have the front and back cables crossed over in the harness?
    What happens when you adjust the fader with music playing?? does it all go to the right speakers?
  7. cliveywolves
    cliveywolves Member
    229
    Hi , i dont have bose,, but i have 100% checked the fader/balance in all modes of playback and works perfectly correct....:rolleyes:
  8. gizze
    gizze Member
    645
    Well if you have the Nav voice coming out of the rear speakers it would suggest that you have something wired wrong.
    I would look at the cable again and check the pins from the original end and the rns-e end go to the right locations. Becuase some of the speakers are driven off the head unit and some are driven off an amp you can get weird results when wired incorrectly.
  9. guayacan
    guayacan New Member
    How do I change this please Gizze. It is driving me daft. Where does the code go?
    Thanks for your time and consideration in this matter pal.
    Max
  10. Keane
    Keane Active Member
    459
    66
    Need vag-com too recode the rnse pal :)
  11. IceHanger
    IceHanger Active Member VCDS Map User
    340
    64
    holy thread revival, :jester:think this is the best one so far!!
    wuta3 likes this.
  12. guayacan
    guayacan New Member
    That sounds like money to me. Is it much?
  13. hades-
    9,481
    646
    look on the vcds map for someone close to sort it for you
  14. hollow
    hollow Well-Known Member
    1,404
    162
    that wont fix it the update has cocked it up . need to upgrade to firmware 650 or 660 to get it back to the front drivers speaker.
    i know cos i just spent 2 days doing same thing after enabling sds voice commands
  15. hollow
    1,404
    162
    module 37 navigation/ adaption channels
