RNS-E + Factory AUX Port (No BOSE)
1PRH Sep 2, 2012
  1. 1PRH
    1PRH New Member
    Hi - First post, sorry if it is in the wrong place..! I have a 2009 Audi A3 with the factory fitted AUX port - No BOSE. I have an RNSE with chrome buttons to fit but am not sure how I would go around integrating the existing AUX port into it. Does the AUX port have to be configured via VAG-COM and/or any other implementations behind the dash required to ensure that it works? The current head unit is an Audi Chorus.
  2. rOb_A
    rOb_A Active Member
    1,488
    yep you'll need to get hold of the 32 pin AMP connector (PN: A1J0 972 977 G) from Audi. cost £4.00 plus you'll need to get the RNSE coded in. bit of cable moving. just done this myself with help of others on here
  3. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Here's a how to guide mate, but this is if you start from scratch. Should be pretty easy to follow from half way through.
    rnseauxin - Audi Retrofit
  4. downtothebone
    downtothebone Active Member Team Scuba Audi A3 Audi Cabriolet Owner Group S-line owners group
    635
    108
    43
    Guide mentions "The first step is to enable Aux-In via VAGCOM - assuming you already have SW0650 installed."
    How do I check this with VCDS?
    Thx.
