Andy Shipton
Hi all,
I would like to ask for help with the following, I am retro fitting the RNS-E from an A4 part number 8EO 035 192 D into a 2004 TT and after some recoding I am having the following problems
1. The radio channel is not displayed in the DIS
2. The auto off function does not work when you remove the key from the ignition
Everything else works, communication with the CD changer and all other functions on the RNS-E work.
I have coded the instruments to 5 which shows the navigation information on the DIS, when the route has finished the display reverts to normal with no radio displayed.
I have attached the VCDS files from the last scan I did yesterday as you can see I have a problem with communications with 2 control modules the instruments and the Navigation,
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N2 920 980 D
Component: KOMBI+WEGFAHRS. M73 D06
Coding: 05462
Shop #: WSC 00000
TRUZZZ8N441009923 AUZ5Z0C6035119
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 D HW: 8E0 035 192 D
Component: RNS-E HIGH EU H72 0550
Revision: 04S Serial number: AUZBZ7F1138426
Coding: 0319113
Shop #: WSC 20619 123 63687
3 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Time Indication: 0
Date: 2009.11.22
Time: 14:40:42
01316 - ABS Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Time Indication: 0
Date: 2009.11.22
Time: 14:40:43
01317 - Control Module in Instrument Cluster (J285)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Time Indication: 0
Date: 2009.11.22
Time: 14:40:53
Freeze Frame:
Bin. Bits: 11011011
Bin. Bits: 01
I recoded the navigation and this coding 0319113 was the one that threw up the least faults, it looks like I am missing a code to communicate with the 2 control modules, please disregard the Radio ZF Output to Antenna Amplifier as I know that the TT does not have the return from the Diversity amplifier and I am trying to resolve this issue with John S3 on the forum, hopefully one of the Nav experts on here will help the missing coding, just a note when I plug the concert 2 back in the everything works fine,
Andy
Coding: 05462
Shop #: WSC 00000
1 Fault Found:
01304 - Radio
Coding: 0319113
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Time Indication: 0
Date: 2009.11.22
Time: 14:40:42
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Time Indication: 0
Date: 2009.11.22
Time: 14:40:43
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Time Indication: 0
Date: 2009.11.22
Time: 14:40:53
Freeze Frame:
Bin. Bits: 11011011
Bin. Bits: 01
Andy
