RNS-E errors since retrofit
Dan-Jnr Aug 3, 2012
  1. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,232
    377
    Hello
    Earlier this year I had an RNS-E retro fitted to my 2002 Audi S3.
    Previously I had the single DIN cd player with storage tray.
    The system works as it should without any problems.
    I ran a check and the following faults appeared, which I tried to clear, but to no avail.
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 T HW: 8E0 035 192 T
    Component: RNS-E HIGH EU H80 X---
    Revision: 20S Serial number: AUZBZ7K1101138
    Coding: 0505711
    Shop #: WSC 63606 123 87607
    VCID: 356A5A5C5F5A571
    7 Faults Found:
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 83
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:56
    Freeze Frame:
    Mileage: 655350 km
    Count: 1507
    Clock: 11:00
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:53
    Freeze Frame:
    Mileage: 655350 km
    Count: 1404
    Clock: 11:10
    00625 - Vehicle Speed Signal
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 63
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:50:12
    Freeze Frame:
    Mileage: 655350 km
    Count: 1404
    Clock: 11:50
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:43
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:43
    00466 - Control Module for Steering Column Electronics (J527)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    01299 - Diagnostic Interface for Data Bus (J533)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Freeze Frame:
    Bin. Bits: 10001
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0505711
    7 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 83
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:56
    Freeze Frame:
    Mileage: 655350 km
    Count: 1507
    Clock: 11:00
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:53
    Freeze Frame:
    Mileage: 655350 km
    Count: 1404
    Clock: 11:10
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 63
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:50:12
    Freeze Frame:
    Mileage: 655350 km
    Count: 1404
    Clock: 11:50
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:43
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:43
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Freeze Frame:
    Bin. Bits: 10001
  2. Jay.Ing
    Jay.Ing Active Member Team Ibis Bronze Supporter Audi A3 Black Edition TDi
    311
    42
    Did you sort this? Have you removed the RNS-E since you installed it?
  3. NHN
    29,284
    1,695
    He has an 8L you have an 8P so of no use to eachother tbh.
  4. a6_chris
    a6_chris Well-Known Member
    1,883
    159
    If you would search you would see that the ZF short to ground is a common error with retrofitted RNS-E due to ~>2007 cars not having the ZF aerial fitted.
    This can be fitted but most people don't bother but you will notice a small drop in FM signal because of the aerial the RNSE uses is not fitted.
    Both this and the Speaker connection errors can be ignored.
  5. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    no probs i thought i did quote him
    im useing a phone well was when i posted and the swear filter usaly ******* the swear word
    i think thats needs looking at
  6. hades-
    9,480
    646
    oh yeah and i did meen to thank you for the part numbers etc i forgot
    so TY.
