Rns-E Drive Replacement
jwhat Mar 26, 2014
  1. jwhat
    jwhat Member VCDS Map User
    541
    Can anyone recommend someone to replace the DVD Drive in my Rns-E please?
  2. hades-
    9,480
    646
    DIY its easy
    if you can get the drive
  3. NHN
    29,295
    1,701
    I've replaced a few, is it a mk1 or mk2 unit?
  4. jwhat
    541
    I'd prefer to give it to someone else to do really.
    It's a Mk1. I've send you a PM about it.
  5. tetskoma
    tetskoma New Member
    10
    Sorry for digging out the old topic.
    I am trying to replace DVD drive in RNS-E (mk2 Led version) as I get 'disc eject mechanism error' on VCDS.
    It is a bit funny, because if I manage to put a disc in, it works as normal, but if I reject a disc. The drive keeps trying to eject and never stops.
    Once it start like that, it won't stop even after I plug off and on the connector. Very occasionary, it stops and I can put a disc back - then it works.
    Maybe I just should leave the latest map disc in, but I would like to fix it.
    If I buy a replacement disc drive, is that just simple swap as you answered above before?
    I already stripped it out and removed the drive actually. Can I just put a new one in?
    Do I need to do coding or something through VCDS or something else?
    I am asking this because I saw a few people saying I would have to pair the drive to the motherboard of RNS-E. I may need a speacial tool (I don't know what it is). Please help and I am so grateful for your advice.
    Thank you. It is MK2 LED version by the way.
  6. NHN
    29,295
    1,701
    It requires soldering skills & you have to swap pcb's over.
    We offer this service if interested.
  7. tetskoma
    tetskoma New Member
    10
    Thank you for your confirmation. But you are not in UK, aren't you?
    I found a private service at £120 or Hazzydays ltd doing at £240 +VAT, but I think I can claim the cost to a Warranty.
  8. NHN
    29,295
    1,701
    I am in the UK, but £120 is very cheap, that sounds more like a laser replacement rather than drive, drives are about £120+ alone, we can swap the drive out for cheaper than hazzydays but not as cheap as £120.
  9. tetskoma
    tetskoma New Member
    10
    Hi. Thanks.
    Yes, this guy sounds too cheap, but he just confirmed (10 mins ago) that he would replace the whole disc and he understands he needs to work on PCB because of the issue, but I use him only if I cannot make an insurance claim (ie I have to cover the costs).
    The reason I am thinking of using Hazzydays is that they can help me to claim this repair to Auto Guard.
    Hazzydays is dealing with Auto Guard many times in the past.
    Where are you based? Can you help me to make a claim as well?
    If so, I'd rather ask you then.
    Thank you.
  10. NHN
    29,295
    1,701
    I suspect they will require vat registered company, of which I'm not, of course an invoice can be provided for the job.
