RNS-E controller
denraf Jan 11, 2011
  1. denraf
    denraf Member
    80
    I'm looking for more information about the "remote control" in the centre for the RNS-E.
    All I could find so far are these three numbers:
    8P0 919 721 5PR
    8P0 919 721 A 5PR
    8P0 919 721 B 5PR
    Did somebody retrofit this already? Is there some more information about the different versions, cabling, ...
    Thank you
  2. hades-
    9,481
    646
    what remote for the rns-e ?
    the only remote i know about is for the nav that displays in the dis and dosc in the boot
    not the rns-e
  3. denraf
    denraf Member
    80
    The "multiple switch for navigation system with display in dash panel insert"
    Picture:
  4. hades-
    9,481
    646
    yes thats not for the RNS-E
  5. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    Hmm, now that I like.
    Keen to know about this myself.
    The A & B variants appear to be linked to auxiliary heater looking at the PR codes on ETKA.
    8P0 919 721 5PR multi switch with navigation and insert dash display
    8P0 919 721 A 5PR multi switch for aux heaters
    8P0 919 721 B 5PR multi switch with nav, insert dash display & aux heaters
    I found this link but the link to the wiring is down - http://www.audi-sport.net/vb/car-entertainment/43010-were-can-i-buy-just-switches-bns-info-them.html
    Maybe S8Craig could help.
    I did find this -
    http://martinsuniverse.de/projekte/navinachruestung/naviverdrahtung.pdf
  6. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    60
    That looks like the satnav remote from something like an A6 - but the in-dash one... Are you sure it's a standalone unit and not just something that pop's into the instrument panel next to the electron handbrake in an A6?
    There's no IR receiver in an RNS-E, is there? So anything that you buy, you'll need an IR eye too.
    I've got a remote for mine, but it only controls the TV function via an IR eye in the glovebox.
    The only other "control unit" is the bit that sits between the steering wheel and the RNS-E.
  7. kite
    kite Member VCDS Map User
    677
    Thats the controller out of an A4 (b6) with lowline nav fitted at the factory..
    It goes where the cig lighter is....
  8. BahnStormer77
    2,773
    60
    hmmm.... just use the steering activated voice control instead ;)
