RNS-E connectors what what what?
funguf May 3, 2007
  1. funguf
    funguf Sunday Driver
    81
    Hi All,
    I'm planning to get a RNS-E to replace the Symphony II in my A3 8P but I'm confused as to what connectors/leads I need.
    Note: The car has Bose speakers.
    Thanks!! :rockwoot:
  2. arthurfuxake
    1,308
  3. JamS3
    JamS3 Active Member
    2,258
    24
    Is it a 2007 model?
    If so you won't need any extra connectors, only need to move the BOSE wire to another pin on the existing loom you have.
  4. JamS3
    JamS3 Active Member
    2,258
    24
    If not have a look on
    http://www.kufatec.de
    Then click on "zum shop" on the right hand side and you should be able to order the right cable.
  5. benw123
    benw123 Moderator
    1,863
    Depending where you buy your RNS-E (e.g. eBay), the vendor may be able to supply an connector for you. By the sound if it, if you have a Symphony II you don't own a 2007 MY car.
    The connectors are generic in that they will fit all types of setups (i.e. with or without Bose) but can be configured for each.
    If your RNS-E vendor doesn't supply a connector, as JamS3 says kufatec supply them separately. However, I've read lots of accounts that their order processing is a bit slow, so delivery may take some time.
