RNS-E Coding
Jay.Ing Aug 3, 2012
  1. Jay.Ing
    Jay.Ing Active Member Team Ibis Bronze Supporter Audi A3 Black Edition TDi
    344
    58
    Hi all, well I picked up my white Sportback BE today, and I've been installing my RNS-E this afternoon. :rockwoot:
    All went well apart from a bit of coding, I have Bluetooth installed from build, for the coding on 56 (nav system) what value do I need to have in 0xxx?xx: telephone/telematics? At the moment it is 7 baseplate diagnostic capable with diagnostic. I can not access any of my contacts, dialled list etc they are all greyed out.
    Any help would be much appreciated
  2. audicruiser
    audicruiser Audi Heaven
    1,865
  3. rich1
    rich1 Member
    82
    Can you upload some pics of your car? I'm picking mine up on the 1st september and cant wait but have loads to fit on it before i 'pick it up'.
  4. Jay.Ing
    344
    58
    Im trying 7 but its not accepting it, keeps giving me an error! :sorry:
  5. audicruiser
    1,865
    Don't know then mate, I haven't got Bluetooth so wasn't an issue I had to sort...
  6. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Not sure if you got my PM, anyhow you won't get contacts, dialled numbers etc etc until you code you telephone module 77.
    You need to code for comfort control via RNS-e, also the installation list needs to be coded. Should be something like this
    Module 77> 7 coding
    0x?xxxx
    1=Comfort (for RNS-E high/Low)
    0xxx?xx
    3=Head Unit (e.g RNS-E) & Diagnostics via CAN (if you DO NOT have a MFSW)
    or
    4=Multi Function Steering Wheel & Head unit (e.g. RNS-E) & Diagnostics vai CAN
    When done, you need to reboot the RNS-E, i think, can't quite remeber, but you hold the power and the top left button.
    You should then find the RNS-E connects to your phone via bluetooth and gives all contacts, dialled numbers etc etc.
  7. Jay.Ing
    344
    58
    Just got your PM now cheers for the offer! Ill try it again tomorrow and let u know! Will i get a little bluetooth symbol in the RNSe?
  8. jasonc
    jasonc Active Member Audi S3
    256
    I did the following coding to get mine working (RNS-E Mk2 + Bluetooth in an S3):
    CAN Gateway – tick the Telephone module
    Radio/Navigation – 0209755
    Telephone – 0011422
    As already mentioned you must turn on the "comfort" mode to make the phonebook work.
    When it's all working you should get a bluetooth icon and see the phone signal strength displayed at the bottom of the Sat Nav screen.
  9. Jay.Ing
    344
    58
    Did you tick the navigation module in the CAN gateway?
  10. jasonc
    256
    Yes, you definitely need that ticked.
    The coding I posted earlier was from when I added the Bluetooth (already had the RNS-E installed) which is why it wasn't mentioned.
  11. Jay.Ing
    344
    58
    Right the telephone module is coded 0011422, the rnse is coded 0209755 and radio, navigation and telephone are coded to the CAN gateway, how ever i am still not able to access my phonebook from rnse and i dont have a little bluetooth symbol at the bottom of the screen!????
    Any more ideas???
  12. Dannykn9
    1,123
    56
    You need to reboot your RNS-e
  13. Jay.Ing
    344
    58
    rebooted, disconnected battery, pulled fuses still no contacts :(
  14. jasonc
    256
    Have you actually paired the phone to the car's Bluetooth? You have to search for Bluetooth accessories on the phone and it should find an Audi one then just enter the passcode to pair them (think it's 1234).
    Sorry if I'm stating the obvious and you've done this!
  15. Jay.Ing
    344
    58
    Yep phone is paired, you wouldn't even get into that menu if it wasn't paired.
