RNS-E coding
A3Bash Jul 22, 2011
  1. A3Bash
    A3Bash Member
    169
    Hi, I need some help coding the rns e to my S3. The car is a 58 plate 8P3 and it had the concert unit before.
    The car has, Bose sound system, Bluetooth, aux and iPod connection (cd changer).
    The aux does not seem to work but eveything else is working apart from the fuzzy sounds on the Bluetooth. Which I think maybe because I have not changed the pin for Bose, where does it go?
    Also the address book from my blackberry 9780 does not seem to show up with the factory Bluetooth.
    The current coding is:
    Navigation: 0209757
    Telephone: 0011422
    Is that the correct coding for my car?
  2. DaztheGuv
    DaztheGuv Member VCDS Map User
    92
    Let me know the full spec, and I'll have a look.
    Has it Got Bose, multifunction steering wheel ect?
    Daz.
  3. DaztheGuv
    92
  4. A3Bash
    A3Bash Member
    169
    I'll have a look on there as well thanks. It's got a multi-function steering wheel, Bose sound system, Bluetooth, aux and iPod connection (cd changer).
  5. DaztheGuv
    92
    I'd say your coding should be:
    {Instrument Cluster}
    Control Module Coding
    Select 56 (Radio System)
    Coding -> Function 07
    0:
    2: Audi S3 (8P)
    0: Malfunction diagnosis for front loudspeakers active
    9: Sound System
    7: Base plate diagnostic capable with comfort control
    1: No additional Tuner
    7: CD-Changer and Multi-Function Steering Wheel installed
    so 0209717
    Then you need to change:
    Control Module Adaptation
    Adaptation -> Function 10
    -> Channel 001 (Tire Circumference)
    The tire circumference is beeing adapted in "mm", a tire circumference table can be found here.
    {Tire Circumference Table}
    Summer Tires
    1790 - 145/80 R14
    1815 - 165/65 R15
    1803 - 175/60 R15
    1806 - 185/50 R15
    1935 - 195/65 R15
    1910 - 205/60 R15
    1930 - 205/55 R16
    1818 - 205/40 ZR17
    1960 - 215/55 R16
    2060 - 225/60 R16
    1930 - 225/45 R17
    2074 - 225/55 R17
    1943 - 225/40 ZR18
    -> Channel 002 (Wheel Pulse)
    The wheel pulse describes the amount of wheel pulses per tire revolution. If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
    43 - Audi A3 (8P)
    This should be it (Thanks to Warren Cox)
  6. Adam.
    Adam. Meow.
    662
    34
    Can't get my 9780 to sync with the RNSE in my dad's A3...... :(
  7. A3Bash
    A3Bash Member
    169
    Hi many thanks for all the replies. The car is all sorted now and the Bose sound system sounds like it should:cool:
  8. A3Bash
    A3Bash Member
    169
    Also, the Blackberry 9780 won't sync. My brothers Iphone did though.
  9. DaztheGuv
    92
    Looks like a conflict between Blackberry and car kit?
  10. A3Bash
    A3Bash Member
    169
    Well on the Audi website it says the Iphone will sync just like the Blackberry 9700. The 9780 is more recent and isn't mentioned on their website.
  11. Avus Sportback
    Avus Sportback Member
    Can someone plz confirm, I have the same kit as A3bash and I'm trying to code the RNS-E (mk2), in the Can gateway 19 I have ticked Navigation, do I need to uncheck radio? Can you also confirm the code for telephone is 0011422.
    Do I need to change another module coding?
    Thanks in advance!
