rns-e code help please
gas-man Dec 28, 2012
  1. gas-man
    gas-man Member
    215
    ok guys
    been in promise land since november :banghead:
    so still need to get my rns-e coded been waiting and waiting but getting nowhere
    so if anybody can code my car for the rns-e to work correctly and wants to earn some beer tokens in the midlands
    since the install the telephone section will not work
    and the dis will not display the nav
    everything else seems to work fine
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    28,031
    11,162
    ​Try users voorhees or arrkon for vcds scan :) x
  3. chrisa4quat
    chrisa4quat Active Member
    970
    29
    I can try. Unsure on process but have vcds at work
  4. Sandra
    28,031
    11,162
    Also try user lewis583 he is on the user map and see he is online just now. Hope that helps, would also be helpfulif you can tell us where in the midlands you are. :) x
  5. gas-man
    gas-man Member
    215
  6. gas-man
    gas-man Member
    215
  7. chrisa4quat
    970
    29
    In sure it aint a problem. If its like coding Xenons etc then easily done I did my Xenons so should be straight forward
  8. gas-man
    gas-man Member
    215
    thats great thanks
    should i try and get the codes we might need?
    where about are you ? and when would it suit you to have a go?
  9. chrisa4quat
    970
    29
    I'm in leicester. Where are you? Have branches scattered in midlands. As I said I'm sure I can get codes. I k ow where to look
  10. gas-man
    gas-man Member
    215
    i,m in birmingham south by the airport
  11. chrisa4quat
    970
    29
    Have a garage in tamworth and Hinckley. I'm sure they could assist ya for a drink or something save travelling if any good?
  12. gas-man
    gas-man Member
    215
    tamworth is good for me chris but could go to either i just know tamworth a bit better
    be grateful if you could organise it to suit the garage as i,m pretty flexible apart from tomorrow
    not a lot going on at the moment
    pm me with the details if you would mate
    thanks again regards Derek
  13. NHN
    29,596
    1,782
    I'm away or I could of done it near one of my installs, if you get stuck then beginning of Jan is my best offer.
  14. gas-man
    gas-man Member
    215
  15. chrisa4quat
    970
    29
    We re open on 2nd. Ill have a chat and let you know
  16. gas-man
    gas-man Member
    215
    ok thanks chris
  17. rowdyboy
    rowdyboy Member
    804
    19
    You don't need to code it mate, when you retrofit RNS-E, it doesn't display automatically on the DIS. That's one of the downsides to the retrofit, I've also done it.
    You have to turn the unit off and back on again to get the DIS display up.
    I had mine coded when I was fitting cruise, it worked perfectly for a couple of years before that and coding made no difference.
    just seen the bit about your telephone not working, I can't advise on that, sorry.
  18. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,054
    793
    A retrofitted RNS-E does display on the colour DIS without any problems, however if you have RED DIS you will have to switch the unit on and off after you have set the route, it's a bug with the red dis which Audi never fixed so only offered the colour DIS with factory fit navigation.
    If you have colour DIS and it's stopped displaying the route I would check the instrument cluster coding, and fault codes.
  19. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    When you retrofit the RNS-E the BT module needs recoding to enable phonebook and call list sharing,and to clear fault codes (some blocking ones usually get set which stop the BT module working).
  20. rowdyboy
    rowdyboy Member
    804
    19
    I just assumed he'd have red DIS, I know there's an almost infinite combination of options.
  21. gas-man
    gas-man Member
    215
    yes guys i do have the red dis,it displays the cd tracks and the radio station in the dis but not the nav
    and when i set a route and turn the unit off and back on the radio or cd information whichever was last being used
    comes back on but not the nav info
    am i right in thinking you have to code the car so it now knows it has a has a rns-e unit installed
  22. PetrolDave
    1,559
    85
    Yes you are, the value in adaptation channel 62 of the instruments needs to be changed before the nav instructions will appear in the DIS.
    Check out the Ross-Tech wiki for the details.
  23. gas-man
    gas-man Member
    215
    chris any news yet ?
  24. chrisa4quat
    970
    29
    ****!! Sorry haven't had chance yet. Been mental at work. Just got ya on too. Ill try and remember tomorrow. If you haven't heard owt ring me at work 0116 2622044 ask for big Chris and ill take ya details and call them then :)
  25. gas-man
    gas-man Member
    215
    thanks bud
