RNS-E Centre Dash Screen?
karbonk Dec 20, 2009
  1. karbonk
    karbonk Living a little!
    182
    After testing the install this evening I noticed in the centre dash it gives you the street road etc. Very clever, I like! But...
    My question is... I used to get the other info on the car. Mileage of fuel left, MPG average etc.
    Is this not an option of having now the RNS-E is installed?
    :beerchug:
  2. you just need to use your stock for controlling the DIS and you can flick through the screens as normal :)
    Davie
  3. karbonk
    182
    Wouldn't work. It was staying the same and says S for south or whatever direction your going and the street name.
  4. s8craig
    1,756
    56
    Turn off compass mode in the NAV setup
  5. I was out in mine the other day with the NAV running and it let me change screens, yours must be setup different to mine.
    Davie
  6. markyzs180
    markyzs180 Member
    543
    you need to use the button on the underside of the stalk, the one that changes from memory1, memory2, off etc
  7. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,386
    112
    as above, button underneath, turn off and back on
  8. karbonk
    182
    You mean the reset button? Im sure I tried that but will give it another go in the morning. Thanks all for your comments. :thumbsup:
  9. karbonk
    182
    Yep tried the reset button today and works now, not sure why it wouldn't work first time round. Allows me to cycle through as normal now. Cheers
