RNS-E + BOSE = spilt eardrums
cazza1729 May 18, 2013
  1. cazza1729
    cazza1729 Filthy Oil Burner
    35
    Popped a RNS-E into my car and with the Bose sound system it is DEAFENING, and not in a good way, the chick from the Satnav voice is breaking me.
    I've tried going through the system to turn down the volume but its on its lowest settings, if I were to plug it into VCDS will I be able to turn it down further or do I need to invest in earplugs?
    Its not just me being weak, after nearly five years in the army my left ear is pretty rubbish anyway, but its still really loud.
  2. NHN
    29,331
    1,716
    All the volume controls are within the setup/sound menu, so I cant see how the voice can be a problem overall & you can easily adjust treble/bass & lower volume if need be, never been an issue I've come across as long as installed properly.
  3. cazza1729
    35
    On my iPhone app it is reading at 95 decibels which is just less than a chainsaw! I'll try adjusting all the treble etc down but the normal radio volume doesn't affect the Nav voice.
  4. immo
    immo Stop me
    275
    40
    When the nav is speaking, use the volume adjuster.
  5. cazza1729
    35
    That doesn't turn Her down, just the radio volume.
  6. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Hsve you tried turning done the volume while she is speaking ? Also did you get the current cable adaptor there s a Bose and a none Bose version.
  7. immo
    immo Stop me
    275
    40
    Then something isn't right I can tell you that much.
  8. cazza1729
    35
    Its a 2012 RNSE that has been working fine, Plug-n-play with no dramas apart form the volume. Didn't realise there was a Bose specific cable, what would that connect into? The only other thing that I thought the RNS-E needed was the GPS antenna which is now stuck under my dash.
  9. Cabbyfan
    840
    34
    The Bose amp in the boot is connected differently than in cars without Bose, so there are definitely 2 different cable harnesses. That being said if its just the nav voice that's too loud I'm not sure why the cable harness would make a difference.
  10. cazza1729
    35
    Everything that I unplugged from the Symphony got plugged into the RNS-E (in addition to the GPS receiver), theres a little volume variation between radio stations but the satnav chick is seriously loud.
  11. audicruiser
    audicruiser Audi Heaven
    1,865
    They aren't plug and play totally. The RNS-e needs to be coded for Bose for one and one of the wires on the plug needs to be moved from pin5 to 7.
    The volume should be adjust while the Nav is talking though... If it doesn't then the unit has an issue I would suggest.
  12. cazza1729
    35
    Thanks for the advice, I'll adjust the pins and get it coded next time its in with my fixer.
  13. soulsurfer
    soulsurfer Member
    142
    9
    Jumping on the back of this, is there a way to set a low start up volume for the radio and media player hen turning on the ignition?
  14. Sidhu88
    Sidhu88 Active Member
    808
    76
    If u got to nav menu and find settings or i think press the settings button along the bottom u can manually adjust the nav volume, it may be under a volume options menu. As for excessive noise elsewhere u need to fine tune it i reckon. What audio input are u using? Cos if ur using aux u need to disable any equalisers on the device ur using otherwise they double up with the equaliser in the rns-e and then it sounds like poop.
  15. audicruiser
    1,865
    Short answer is no. If you search the forum this has been discussed before as an annoyance of the 8P A3.....
