RNS-E Bluetooth info please
Blackie Oct 6, 2011
  1. Blackie
    Blackie Active Member
    697
    67
    Right chaps. Been a while since i swapped out a single din for an RNS-e.
    Anyway swapped it all over & its good to go , however i bid on a BT box with kufatec lead on the bay of fleas
    Its all fitted & working but after researching i found out its a D model which has basic functions
    At what suffix no do you get the singing dancing & does anyone have one for sale ?
    Ta
  2. kite
    kite Member VCDS Map User
    676
    From Audiforums.us
    PHONE INTERFACE BOX Full functionality unless shown otherwise
    8E0 862 335 <MY 2005.5 A4 (North America) - no Bluetooth
    8P0 862 335 <MY 2004 A3 - Basic functionality only
    8P0 862 335 A MY 2004 A3/A4 - Basic functionality only
    8P0 862 335 D MY 2005 A4 >8E-5-533 000 - Basic functionality only
    8P0 862 335 E MY 2005 A4 8E-5-533 001>>8E-5-600 000 - Basic functionality only
    8P0 862 335 C MY 2006 A4 8E-6-000 001/8E-6-800 001>>
    8P0 862 335 B MY 2006 A3/A4 (North America)
    8P0 862 335 F MY 2006.5 A3/A4 (Europe)
    8P0 862 335 G MY 2006.5 A4 (North America)
    8P0 862 335 M MY 2007 (Europe)
    8P0 862 335 J MY 2007 (North America)
    8P0 862 335 H MY 2007.5 (Europe)
    8P0 862 335 L MY 2008 (North America)
    8P0 862 335 K MY 2008 (Europe, sw 0340) -> may get replaced under warranty due to faulty firmware
    8P0 862 335 Q MY 2008 (Europe, sw 0350)
    8P0 862 335 R MY 2008 (North America)
    8P0 862 335 N MY 2009 (Europe)
    8P0 862 335 P MY 2009 (North America)
    8P0 862 335 S MY 2009.5 (Europe)
    8P0 862 335 T MY 2009.5 (North America)
    8P0 862 335 AA MY 2010 (Europe)
    8P0 862 335 AB MY 2010 (North America)
    8P1 862 335 MY 2011 (Europe)
    8L1 862 373A - Microphone
    8J0 862 373 B - Microphone BOSE/TEL for TT 8J, R8 and 8P cabrio
    8P0 035 503E - Bluetooth Antenna
    8T0 862 336 A MY 2009 (Europe) for B8 A4, A5 & Q5 without MMI
    8T0 862 336 B MY 2010 (Europe) for B8 A4, A5 & Q5 without MMI ​
  3. Blackie
    697
    67
    Thanks mate
    Am i correct in assuming that i need to get as late a model as possible ? I have the latest RNS-E
  4. kite
    676
    yep..newer the better
  5. Blackie
    697
    67
    Managed to bag an AA version on the bay. Hopefully that will sort it
  6. Blackie
    697
    67
    Right chaps
    Ive changed it over to the AA version but still cannot get it to store the numbers etc etc. What do i need to do to get this bloody thing to work.
    I have looked on VAG & i know i,m a stump & obviously missing summat.
    I have the MK 2 RNS-e with no MFSW & the AA version bluetooth unit.
    Cheers in advance as its doing my head in.....................
  7. kite
    676
    it could be a setting on your phone that is wrong.
    the first time I connected my new phone it took quite a while to download the phonebook.
  8. s8craig
    1,740
    53
    It would be nice to know which model of car, mfsw fitted? and phone you have for the correct coding of your BT setup.
  9. Blackie
    697
    67
    Cheers for that.
    I will check the BT number tonight
    Its an A3 8P
    Latest G Navi
    No MFSW
    AA model BT box
    Kufatec BT lead.
    I think thats it. Poverty Sat nav :)
  10. s8craig
    1,740
    53
    Coding?
    Phone type?
  11. Blackie
    697
    67
    Thanks again
    Phone is Iphone 4. I will extract the coding later.
    It is working & says BT on and makes/receives calls bt only has basic functions as per the D unit i had fitted earlier.
  12. s8craig
    1,740
    53
    The RNS-E requires a 7 in it's coding, so it would be something like this 0xxx7xx where x=existing coding, after coding you should reset the RNS-E by holding radio and setup until the screen blanks.
    The telephone should be 0010322 as you have no MFSW.
  13. Blackie
    697
    67
    I will check later and report back
