RNS-E and FBMFSW into 8P2 S3
Brodster Apr 10, 2012
  1. quinnii
    quinnii Active Member
    328
    94
    Can anybody also clarify if this value is correct for the Bose system:
    3) Setting up the bose sound system characteristics (Module 56 - Function 7 - Sound characteristics - Option 5)
    As the information here says that the Bose is option 9:
    VAG Codes for RNS-E | Audi Forum
  2. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,553
    896
    Did a little research on tinterweb this morning and went out and coded the car. Seems to be all working. I have ZF antenna fault but Im not really bothered about that at the moment. This is what I did.
    RNSE Coding:
    [ 37 - Navigation ] --> [ Coding - 07 ] --> Software Coding: --> [ Do It! ]
    Adaption Channels:
    [ 37 - Navigation ] --> [ Adaption 10 ]
    1. Type the adaption channel you wish to change into 'Channel' and click 'Read'.
    2. Make a note of the existing 'Stored value' (You may find that the stored value already matches the value you need to enter in which case you can skip to the next channel).
    3. Enter the new value required into the 'New Value' box, click [ Test ] --> [ Save ]
    4. Repeat 1 to 3 for each RNS-E adaption channel below
    Channel 001: 1943
    Channel 002: 43
    Channel 003: 1
    Channel 004: 0
    Channel 005: 0
    Channel 008: 255
    Channel 010: 0
    Channel 018: 1
    Channel 067: 000
    Channel 099: 0
    Channel 136: 00013
    Once you have changed all the required channels you can click [ Done, Go Back ] to return to the control module screen, then
    [ Close Controller, Go Back - 06 ] to close the current control module.
    Bluetooth Coding:
    [ 77 - Telephone ] --> [ Coding - 07 ] --> Software Coding: --> [ Do It! ]
    Adaption Channels:
    [ 77 - Telephone ] --> [ Adaption 10 ]
    Use steps 1 - 4 for the RNS-E with the bluetooth adaption channels, again you may find that the values already configured match those required.
    Channel 133: 1 (Bluetooth ON)
    Channel 134: 0
    Channel 135: Enter your 4 digit bluetooth pin code (default: 1234)
    CAN-Gateway Coding
    You need to ensure the following items are enabled/ticked in your CAN-Gateway, LEAVE ALL OTHER OPTIONS UNCHANGED.
    We strongly recommend that you use the Long Coding Helper in VCDS to do this.
    [19 - CAN-Gateway] --> [7 - Coding]
    IMPORTANT! - Copy the coding from 'Current Coding' and make a backup of it somewhere
    Click 'Long Coding Helper'
    Select Byte 3 (the 4th pair of digits along line 3) - it should say "Byte 3" in the box
    Change bits 3 to 7 on your gateway to match those below, leave bits 0 to 2 UNCHANGED.
    Byte 03
    • Bit 0 [3D] Special Function - LEAVE UNCHANGED
    • Bit 1 [47] Sound System - LEAVE UNCHANGED
    • Bit 2 [75] Telematics - LEAVE UNCHANGED
    • Bit 3 [37] Navigation
    • Bit 4 [57] TV-Tuner
    • Bit 5 [0F] Digital Radio
    • Bit 6 [56] Radio
    • Bit 7 [77] Telephone
    Press "Esc" or click "Exit" from the Long Coding Helper Window
    Check that the number in 'Current Coding' has changed from what you noted down (a maximum of 2 digits should changed)
    [Do It!]
    [ Done, Go Back ] to return to the control module screen, then [ Close Controller, Go Back - 06 ] to close the current control module.
    N.B. We have had some reports of people not being able to locate the bits to change within the long coding helper. If you experience this, please try selecting the required options in the "Gateway Installation List" which can be found on the Auto Scan screen.
    If this happens to you, we would ask that you email us at support@rnsecoding.co.uk to let us know the year and model of vehicle that this has happened to you on. Thank you.
    Reboot RNS-E
    To reboot the unit, hold RADIO (or AM/FM) and SETUP for more than 10 seconds.
    Clear Fault Codes
    Clear any fault codes as some of these generated whilst coding can prevent the system from functioning.
    To clear fault codes, select the module you wish to check
    e.g.
    [ 37 - Navigation ] --> [ Fault Codes - 02 ] --> [ Clear Codes - 05 ] --> [ Done, Go Back ] --> [ Close Controller, Go Back - 06 ]
    [ 77 - Telephone ] --> [ Fault Codes - 02 ] --> [ Clear Codes - 05 ] --> [ Done, Go Back ] --> [ Close Controller, Go Back - 06 ]
    You may find it easier to run a complete auto scan on your vehicle and that will show you which modules have faults that need to be cleared. You can then use the above procedure examples to work through and clear them.
    Thanks to all that contributed to me eventually getting there.
    FBMFSW fitment next IF and when I get hold of a new steering module.....fingers crossed. Any one got one up for grabs???
  3. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,815
    10,916
    Good morning Brodster, i have been following your progress in here since you started yesterday. Sounds like you had a real fun time with it. You have had lots of good input from the guys along the way. Glad its up and running. What steering module is it that your looking for? If you have the part no, put a wanted post in the classified section and see if there is one available. Very good write up. Maybe you could write a seperate post in the 8p section for others to follow as its always useful and we can turn it into a condensed sticky thread, photos can be included if you have them. Thanks. Sandra. :)
  4. Brodster
    3,553
    896
    Cheers Sandra. I wouldnt say fun was had at the beginning but once I knew the equipment I had wasnt needed then I was like a 'whippet out of a snake bag'. Its good when things like this go well. Standby for the FBMFSW saga.....coz it will be.
  5. Sandra
    27,815
    10,916
    If its as good as this thread, i cant wait. Job well done. :)
  6. Blackie
    Blackie Active Member
    697
    67
  7. mike foster
    3,967
    Sandra - is this not the 8P section ?!!!lol
    Steering module he requires is 8P0 953 549 F
  8. Sandra
    27,815
    10,916
    Yes Mike it is the 8p section, lol. My concentration level is bad today. Im sure you will forgive me though. :)
    User itwasntme187 has one of those steering modules in the classified section, dont know if he will sell it seperately from the mfsw though. :)
  9. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    Just read this post with interest and i need a control module as well. Found one on ebay froma VW with the part number
    VW Part Number: 1K0 953 549 AF - 1K0 953 549 AF - 1K0 953 549 AF
    Anyone know if this is will work on my S3 8P to make the MFSW work as its doing my nut in not working!?
  10. mike foster
    3,967
    No it will not work for mfsw. I had that in my car and had to change to 8P0 953 549 F. It will work for cruise control though, operating in the 'alternative' mode.
    Sorry !
  11. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    Hey Dude, well done on fitting and coding your RNS-E! Sorry, but I didn't get your visitor message about this until a couple of mins ago. You seem to have it all well and truly done and dusted now though. Good job! As requested, will happily spread the gospel according to SHARK to anyone who will listen, lol. Congrats on that too! :wub: xx
  12. JamesS4cab
    1,191
    94
    Perfect - saved me £40!! Thanks mate!!
    Just need to find someone that doesnt want to rip people off for £120 for the right one.
  13. Brodster
    3,553
    896
    That guy on Ebay will not budge on the selling price for the steering module....A little expensive me thinks.
  14. Sandra
    27,815
    10,916
    Mark, have you tried asking Nigel, user NHN if he has one lying around? Worth a try. :)
  15. Brodster
    3,553
    896
    Yeah I have Sandra. Might just use his services to fit the wheel and cruise IF hes coming to Bonny Scotland.......fingers crossed.
  16. mike foster
    3,967
    Sandra - that particular steering module is like gold dust ! lol It's the only one guaranteed to be suitable for mfsw.
    No one has ' one lying around' and I'm not surprised the ebay guy won't budge because it's £175 from Audi !
    Only possibility is to find someone selling mfsw and suitable steering module together and if you can get them for less than £250 you're doing well.
  17. Sandra
    27,815
    10,916
    Lol Mike, you following me around today. Ash user itwasntme187 has the module but wants to sell with with mfsw. I do try, lol. :)
  18. mike foster
    3,967
    Not following you round deliberately - just seems like our paths are coincidentally crossing ! lol
    It's a subject I know a lot about due to expensive personal experience so don't want anyone to go wrong like I did.
  19. Sandra
    27,815
    10,916
    We are just both naturally helpful people. Lmao. :)
  20. mike foster
    3,967
    Being a moderator, you are, of course, totally correct !:icon_thumright:
  21. Sandra
    27,815
    10,916
    I havent given up yet though. Im waiting on a reply. :)
  22. JamesS4cab
    1,191
    94
    I can tell you that Ash is not splitting the module and the wheel. :icon_thumright:
    And Brodster - dont get phased by the steering wheel fitting. I'm a total desk monkey and I swapped one over at the weekend on my wife's a3 and it took 10 mins tops. You just need the right tools and do it in the right order and carefully. I'll even lend you the spline you need for the steering wheel if you like!?
  23. Brodster
    3,553
    896
    Cheers for that mate......may well take you up on the offer. I think I have one but will check 2 moz.
