RNS-e Adapter Cable Question
ian ditch Mar 25, 2009
  1. ian ditch
    ian ditch S-Line Lover
    19
    I've been searching this forum for details about the adapter for the RNS-e
    My car has the bose system, am i correct in thinking that one of these adapters currently on sale on ebay if the right one, all i have to do is remove one of the pins to enable the bose, also that the speakers are powered thru the bose amp, so the speaker block&terminals are not used.
    I'm just checking before i buy this item
    Ta
  2. Issac Hunt
    1,162
    I'd get a specific adapter for BOSE. A non-BOSE adapter can be made to work but you will need to add/remove wires in it.
    Not worth the aggro IMO. Try Kufatec.de
  3. ian ditch
    19
  4. Issac Hunt
    1,162
    BNS is the CD based naviagation option. Its the cheapo nav-option. The RNS-E being the more expensive (and better!) DVD based option.
  5. JohnS3
    JohnS3 Active Member
    3,032
    If your car is an 07 or later (with a concert II double din headunit) you don't need the adaptor.
