rikia93
Hello
I have just fitted the double din cage to my A3 for an RNSE having come from a single din Concert ii.
I then did a scan with Vag-Com to see if things were all dandy and came up with an interesting code that is not the usual ZF short to ground issue that a lot of others seem to be having.
I have the Single fakra and Black ISO aerials and am experiencing severely degraded radio reception.
Saturday,16,November,2013,17:47:35:45558
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 76 7D
VIN: WAUZZZ8P16A147818 Mileage: 161160km/100140miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
Component: RNS-E HIGH EU H73 0550
Revision: 02S Serial number: AUZBZ7G1100609
Coding: 0215351
Shop #: WSC 02197 785 00200
VCID: 3261F556AD9E9788E6F
2 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 126
Mileage: 161164 km
Time Indication: 0
Date: 2013.11.16
Time: 17:36:03
Freeze Frame:
Mileage: 161160 km
Count: 1611
Clock: 17:35
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 126
Mileage: 161164 km
Time Indication: 0
Date: 2013.11.16
Time: 17:36:13
Freeze Frame:
Mileage: 161160 km
Count: 1611
Clock: 17:35
Would greatly appreciate any help on how to fix this!
Cheers Ricky
Chassis Type: 1K0
Coding: 0215351
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 126
Mileage: 161164 km
Time Indication: 0
Date: 2013.11.16
Time: 17:36:03
Freeze Frame:
Mileage: 161160 km
Count: 1611
Clock: 17:35
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 126
Mileage: 161164 km
Time Indication: 0
Date: 2013.11.16
Time: 17:36:13
Freeze Frame:
Mileage: 161160 km
Count: 1611
Clock: 17:35
Cheers Ricky
