RNS-D to RNS-E...Again
cobraBLACK Mar 23, 2012
  1. cobraBLACK
    cobraBLACK Chocolate? It's doo-doo, baby!
    375
    20
    I've bought an RNS-E for my S4 but I want to make sure I'm getting the right cables.
    I considered an eBay special but I'm worried it'll be a waste of money if it isn't compatible with my CD changer and Bose sub and amp.
    On the other hand, Kufatec do an RNS-D to RNS-E upgrade kit, although £70 + shipping is way overpriced.
    Doe anyone have a recommendation please?
  2. slappy
    slappy Member
    205
  3. cobraBLACK
    375
    20
    Ah, see the couple I found were in the vehicle parts section. I didn't think I'd need to look in 'consumer electronics'.
    Do you know if that'll cover everything? I keep hearing about this 'Bose wire'.
  4. slappy
    slappy Member
    205
    Not 100% sure on that, someone will come along and advise. :icon_thumright:
  5. cobraBLACK
    375
    20
    OK, I gave it a go and I got the thing powered up.
    Only radio though. I didn't try an SD card but it didn't recognise the CD changer. I have a 'C' model so I might need to buy a 'D' model.
    I was left with one old connector with no home. Does anyone know what it's for?
    There was a similar sized 32-pin socket in the back of the RNS-E but it didn't seem to fit (although I might have had the lock handle in the wrong position).
    The only other concern is Bose - I can see an empty Bose pin hole on adapter harness I got from eBay but I don't know where it would be coming from in the car's wiring.
  6. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    Did you have TV or anything extra on the D?
  7. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    That 26 pin connector carries the CAN-BUS-L(26) & H(13) signals and a few others - this connector is unique to the RNS-D unit.
    Here is a link to wiring from RNS-D to RNS-E.
    CD may not work if you have not coded the RNS-E to tell it to look for the respective add-on units. Look here for coding information.
  8. cobraBLACK
    375
    20
    That's very interesting.
    I'm still perplexed about the Bose wiring though - I've no idea what I need to do.
    Is that table saying I have to ground RNS-E pin B/7 and vehicle pin 10, then connect RNS-E pin D/14 to a 'large brown single-pin connector'?
    I've been told the changer doesn't need coding but I was gonna get it checked anyway.
    Perhaps with the use of SD cards there will be no need for a CD changer anyway but it would be nice to have it working without having to spend any extra money.
  9. Woorlord
    951
    17
    RNS-E D/14 can stay disconnected - it is on my loom. (I went from Concert II to RNS-E). My alarm works fine and I get no errors on scanning.
    RNS-E pin B/7 to Connector III/Pin 1 - (this can also stay disconnected and the Bose will still work if all the other connections are made for pre-amp signals and amp power on etc.). I have got a feeling that my loom did not have this wire added as it was non-Bose - I recall adding two pre-amp wires signal. I have full control of Bass/Treble etc. on the RNS-E. My RNS-E is software coded to tell it I have BOSE - my coding is 0309752 have TV input and Aux input and BT phone - the 9 tells it I have Bose, changing this to 1 would be a non-Bose set-up. I have no external CDC.
    You can purchase repair wires from Audi and insert missing ones into the plug housings. I was sold a non-Bose adaptor loom by mistake, and added them to make it work, i.e. added the Rear pre-amp signals for the Bose amp - 2 wires, (LR & RR). All repair wires can be identified here.
    CD Changer may or not need coding, but if it is not working suggest you check all wiring for it - can you eject and insert CD's?
    Can you see the CDC option in the source menu?
    Not using a CDC myself as utilised Video input for i-pod sound and video.
    There is a lot that needs to be checked for 100% correct coding and adaption - including getting instruments unit (Module 17) recoded to show Nav instructions, etc.
    It all depends on what the donor vehicle had fitted and what this RNS-E was matched too.
  10. cobraBLACK
    375
    20
    Oh, OK.
    I saw that reference in one of your other posts:
    Can you tell me what the red bit means please?
    Also, what does this mean?
    Channel 007: Options
    Channel 008: Volume Characteristic
    I went down and put the RNS-E back in and I left it installed this time since the SD cards work fine and the sub/amp is working.
    As for the changer, it powers up and I can eject/load discs but it's not a source option on the RNS-E.
    I'll pop into my garage next week and get them to code it properly.
    There is another unidentified connector. The black bit of plastic swivels around to keep it in place:
    Here's the unplugged connector:
  11. AudiLeon
    2,250
    192
    Looks like the GPS antenna connection.
  12. Woorlord
    951
    17
    Text you highlighted in red - Not sure, but by explanation you set to 0 for Saloon or Avant and 1 if Cabriolet.
    refers to settings stored from within RNS-E settings menu,
    +01: Distance in miles
    +02: Speed in mph
    +04: Time in am/pm
    +08: Date in MM:TT;JJJJ
    +16: Repeat Voice Commands
    not necessary to set this with VCDS - just use the RNS-E menu to set.
    refers to GALA setting as follows,
    000: Speed dependent volume control (GALA) OFF
    001: Characteristic 1
    002:
    003:
    004:
    005: Characteristic 5
    255: GALA via Mic (Bose AudioPilot)
    Set this to 255 if you have the new MIC activated BOSE (post 2004), otherwise selectable via RNS-E menus
  13. cobraBLACK
    375
    20
    Thanks.
    Is that where the volume changes with road noise? Mine does that. The registration date on mine is January 2004.
  14. cobraBLACK
    375
    20
    Sounds about right. Cheers.
  15. cobraBLACK
    375
    20
    Job done!
    You can see details of the resolution here.
