RNS-D coding
SirSpanky May 4, 2010
  1. SirSpanky
    SirSpanky New Member
    Hi everyone!
    I've finally returned to the Audi fold after selling my Coupe Quattro a couple of years ago, but need a little help with my Avant - The MFSW doesn't talk to the nav+.
    I've had a look at the steering module with VCDS and that all looks fine, so where do i need to go from there?
    Thanks in advance.
  2. SirSpanky
    So I managed to find a page about RNS-D coding using the way-back machine to access the Nav-Plus website:
    http://web.archive.org/web/20071026083330/www.nav-plus.com/programming.html
    Everything checks out fine and the "Test Output" in VCDS does perform all the MFSW functions - leaving me with some-sort of connection issue between the buttons on the MFSW and the controller, annoyingly the gear buttons do work.
    Can anybody help out with fault finding on a MFSW, or am I going to have to delay the RNS-E even longer as I'm going to have replace the steering wheel????
  3. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    Firstly, pop your airbag off and see if its become disconnected inside. It may have worked loose some how. Does your horn and everything else work ok?
  4. SirSpanky
    It's all good except for the 6 radio/telephone buttons...
    And popping the air-bag off, hopefully that's not as hard/dangerous as it sounds???:think:
    On a side note, how do I change the thread name as this is now nothing to do with the RNS-D?
  5. AudiLeon
    2,250
    192
    Not sure on changing the title.
    2 Screws hold in the airbag to the steering wheel.
  6. SirSpanky
    Anything I have to be careful about before going mad with a screwdriver?
  7. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,047
    792
    What is the coding of the rns-d and scsm module
