RNS-D, can't select TV
StuG808 Feb 9, 2012
  1. StuG808
    StuG808 1.9tdi130 Avant FailWheelDrive
    257
    9
    Ok, just got my RNS-D decoded, all seems fine in an out-of-date kinda way, apart from being unable to select the TV option. When I push the Radio/CD/TV option, it only flicks between radio and CD and not allowing TV, even at standstill. Granted that I will be lucky to get an analogue signal anyway, but surely it should still switch to the function?
  2. Grangey.
    Grangey. Member
    226
    Does it actually have the tuner add on?
  3. StuG808
    257
    9
    I have no idea, I assumed that it would if it was standard spec, but maybe it's been installed sometime during it's life?
  4. Grangey.
    Grangey. Member
    226
    so you dont actually know if its been installed?
  5. StuG808
    257
    9
    Nope, I imagined that the RNSD had would have it all working as standard. So I have to buy something extra before I get Ceefax in my car?
  6. StuG808
    257
    9
    Ok, I guess this is the thing the car needs before TV will work:
    RNS-D Analog TV Tuner - A8 Parts Forum
    Where would this be installed? Then I can check if it has it or not, if not, then I'm not going to bother buying a tuner.
  7. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,232
    172
    Trouble is it'll be analog though?
  8. hades-
    9,481
    646
    tv tuner was a extra option
    decode all the numbers on the sticker in the service book on in the spare wheel well
    and it will tell you what was fitted at the factory
