Rip off or not ? Lambda Sensor
S3_NDJ Jun 19, 2014
  1. S3_NDJ
    S3_NDJ Member
    368
    Hi all
    I need a bank 1 lambda sensor replacing i have been quoted 190 for a aftermarket part and 230 for a vag part this includes fitting ....
    Rip off or not ?
    Is this the correct part number
    Part number: 022 906 262 Q
    I have found a bosch one online on ebay priced at £69.99
    Are these a easy DIY job ????
  2. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,368
    909
    They are expensive, but not that much mate, Euro Car Parts sell them too, so worth checking with them.
    Have you got the error code, as the S3 has 2 sensors on the car, both will Show as Bank 1, but it should then say S1 or S2, one is behind the engine and the other is by the cat.
  3. S3_NDJ
    S3_NDJ Member
    368
    Its definatly the one behind the engine i have a m8 who works at euro so ill try get some discount aswell ;) thanka nilz
  4. mattyboy199
    mattyboy199 Well-Known Member
    1,891
    29
    soak it in vinager for a week should fix it up nicely, it did on my S2 sensor.
  5. S3_NDJ
    S3_NDJ Member
    368
    Hmmm maybe im getting a quote on a fresh one tomo from euro car parts if its still a far amount i might have a go with some vinegar
  6. Nilz
    11,368
    909
    Does the vinegar trick actually work though?
    Im sure the one on the wifes car is causing an issue, so wouldnt mind giving it a go if it saves some monies!!
  7. JoeeS3
    JoeeS3 Active Member
    464
    105
    43
    i had to change mine the other day, but i just bought a second hand oem one off a breaking car. works fine and all for just £25 delivered
  8. S3_NDJ
    S3_NDJ Member
    368
    Is it easy access at the back of the engine ? Easy DIY job ?
  9. JoeeS3
    464
    105
    43
    If you get the charge pip off its easy enough! But i had a problem with mine where the threads had melted together so had to re-tap the hole. it would have been easy enough with out this problem though.
  10. S3_NDJ
    S3_NDJ Member
    368
    Ok no worries ill look into his before i hand it over to the garage lol cheers for the heeads up
  11. SoljahofSensi
    SoljahofSensi Member
    93
    If it helps, i got an NGK b1s2 sensor off ebay last year as was almost half price of the bosch ones which were £110ish at the time i think
  12. S3_NDJ
    S3_NDJ Member
    368
    Ahh sweet m8 but i have managed to find one for 69.99 and its bosch so ill probs get that one and ask how they will charge in labour to fit it
  13. Nilz
    11,368
    909
  14. S3_NDJ
    S3_NDJ Member
    368
    Thanks nilz i have contacted him waiting for a reply .... Good Find :)
  15. Nilz
    11,368
    909
    No probs mate, hopefully you will get it sorted and save a few bob too :)
  16. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,293
    640
    If it is seized, it is a pain of a job.
    Rick
    S3_NDJ likes this.
  17. nevermore1983
    nevermore1983 Member
    40
    30
    buy a cheep open end spanner and cut it in half make doing it DIY a lot easer
  18. mattyboy199
    1,891
    29
    the vinager soak worked....been going strong for a year, no fault codes & mpg is spot on.
    bigal 1 likes this.
