Riding high on one side
Djwoody Apr 12, 2014
  1. Djwoody
    Djwoody Member
    480
    21
    Hi.
    I have some Eibach Sportlines on my A3 with some 19" rotors.
    On my drivers side, the rear arch sits just over the tyre.
    On the passenger side, there is a visible gap between the arch and tyre, maybe 20mm.
    Not sure which side is the correct height but something isn't right.
    Do you think one of the springs is not seated correctly?
    Chris
  2. weeroughy
    weeroughy Member
    62
    I have the exact same problem.
    H&R springs on bilstein b8 dampers. Also recently fitted an H&R anti roll bar which I think could be the culprit!
  3. Djwoody
    Djwoody Member
    480
    21
    I haven't fitted an anti roll bar so I'm a bit puzzled at the moment. :-(
  4. weeroughy
    weeroughy Member
    62
    It may have been the same before the ARB was fitted but I can't say I noticed!
    I'll hopefully get a good look on Tuesday so might be able to offer more help then!
  5. s3_trev
    s3_trev Northern Ireland Gold Supporter Audi S3 Team Brill Red
    1,843
    624
    Sorry for thread hijack Djwoody..
    Whats your opinion on the H&R springs on bilstein b8 dampers combo?
  6. weeroughy
    weeroughy Member
    62
    The spring/damper combo alone I can't really comment on specifically, as I had the rear ARB upgraded at the same time so all experiences of the dampers include the ARB also.
    The ride quality is reduced obviously, but not so much the car is uncomfortable. Several of my mates are using coilovers on daily cars and in most journeys it gets very tiring very quickly! Which is the reason I chose springs and dampers over coilovers, as I do quite a few miles.
    The handling is much better! It feels solid in corners and doesn't skip over bumps as much as friends cars with coilovers.
    The 'turn-in' is much better also, but I have bought a white line anti lift kit and front ARB to improve the front end a bit, as the 2.0 tdi is much heavier up front than other cars I've owned and is noticeable to me when driving!
    Overall I would definitely recommend it, I spoke with Damian at DPM and he assured me the b8's were one of the best dampers on the market in the price range I was looking at and I have not been disappointed at all!
  7. Westy
    Westy Well-Known Member
    17,438
    1,093
    My car sits higher one side then the other at the rear on AP coilovers. One adjuster is 10mm different to the other. I have no idea what causes this to be out.
    irowpod likes this.
