Rich under load, lean at idle ?
ben4866 Nov 6, 2009
  1. ben4866
    ben4866 Member
    46
    Looking for second opinions, my AGU is running rich under load and lean at idle according to vag com. It seems to lack torque at low rpm until above 3k and fuel consumption is poor even when driving steady.
    Any ideas ?
    Thanks.
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    AFM or Lambda would be my first guesses, more AFM though... it doesn't normally produce VAG COM fault codes either.
    At least it's running rich when the loud pedal is pressed, lean being the enemy!!
  3. badger5
    9,507
    2,003
    your judging this thru vagcom on a narrow band lambda?
    which block are you using?
  4. ben4866
    ben4866 Member
    46
    Yes vag com and narrow band, can't remember which block it was but I followed Rosstech guide to fuel trims.
  5. badger5
    9,507
    2,003
    narrow band is not accurate for judging afr as you are trying to do
  6. Welly
    10,696
    129
    Bill, have you got a wide band lambda for this sort of testing? I wouldn't knowing how my fuelling is doing...
  7. ben4866
    ben4866 Member
    46
    Ah ok thanks for your input.
    I did notice today however that at idle the engine seems to rev up and down, you can hear the tone goin up and down constantly. Ive done a throttle body clean and alignment with vag com. Oh and I'm getting roughly 23-24 to the gallon driving steady ?
    I appreciate your help.
  8. djb83
    djb83 redline responsibly
    68
    thats lucky 23-24mpg mines hasn't been above 22 mpg and ive had the car about 7 months now :shrug:
  9. Welly
    10,696
    129
    Bloody hell, mine is running more boost than it's meant to on a Stage 1 map and a fair wack of other mods and I'm getting a 27 average and that caning it a fair bit since I've got a lead right foot...
    Am I just lucky?
  10. ben4866
    ben4866 Member
    46
    WOW ! Either my bog standard AGU isn't running correctly or you are lucky !
  11. Welly
    10,696
    129
    As Terry Tibbs would say... Fack knows. Drops to 5 MPG when I give it hammer though!! :banghead:
  12. con1.8t
    con1.8t New Member
    17
    22mpg !!! wow i can get mine up to mid 30s n still have fun its all about revs and keeping the momentum going .but i am a taxi driver so when I'm not in race mode i can't help driving as economical as possible ... good tips are over 2.2k is bad don't over break in corners n don't press ya clutch till stall speeds . trust me try this and your mpg will go rate up
  13. A3ster
    A3ster Member
    87
    I have an AGU aswell and return around 28mpg.
  14. badger5
    9,507
    2,003
    yes I do, thats how I would do a narrow band car when mapping
