Rice's S3
Rice Mar 5, 2013
  1. Rice
    Rice Active Member
    247
    37
    Ha that's awesome how did that come up? Do you work for top gear? I like the sport backs :)!
  2. dbm
    dbm Active Member
    621
    168
    43
    No, I bought the car from Audi. I knew it had belonged to them, but I didn't know it was 'famous'.
    I found the video by chance, and recognised the number though it has a private plate on now. At least I know it has had adventures!
    AVLO likes this.
  3. Rice
    Rice Active Member
    247
    37
    Ha thats pretty cool!
    So another update for y'all!
    Ordered some new vacuum hoses as i hate blue silicon hoses!!! (just got a couple more to replace as you'll see). I also got round to ordering some genuine screws for the battery and coolant cover, much better than horrible hex bolts it had before.
    So the before shot... Should have fitted it all in so you can see the overall difference with the new screws.
    After
    As i said above just the DV and N75 hoses to change to red or black now.
    Got my paddle clutch from CG motorsport also... Although i am slightly dubious of it as the springs seem so small?! Maybe its just because the springs are further in so its got less of a leverage, so doesn't need as strong springs... I dont know really. But i was recommended them by a mate whos in the motorsport business.
    Having it fitted this weekend as well as a new manifold.
    £454 later at TPS....
    Lucky ive got a mate who works there so got me good rates!
    New manifold, gaskets, nuts, washers, flywheel bolts, one of the bevel box seals (the other i had to source from edinburgh TPS, very helpful i must add), new coilpack as one of mine was a push on one instead of a bolt down, and an N112 valve as it had been bodged with superglue by a previous owner... which i found out when i was replacing the vac hoses -_-.
  4. chaz20vt
    chaz20vt Member
    428
    21
    Nice update there mate like this car a lot
    Was it hard to get a good finish on your headlights with wet n dry.?
    Whats your next plan of action
    Also what size hose did you use for the pipe that comes of the throttle body (the small one)
  5. Rice
    Rice Active Member
    247
    37
    Thanks mate, you keeping the s3 then?
    No really easy, depending on how far gone they are, you start with 800 grit in some soapy water and go side to side up and down, working up to 3000 grit, then a quick polish, some people use a DA/rotary polisher but its easy to bugger them up by getting them too hot.
    Umm, poly bushing it i think... Well that or get a small bit of paint work done on the front arches, got a bit of rust, nothing major.
    Its 8mm internal. 14mm external, so got some new spring clips for it too. I got some ram air hose off silicone hoses off ebay, really nice red, not the usual bright red but slightly deeper, as you can see in the photo.
  6. chaz20vt
    chaz20vt Member
    428
    21
    Yea decided to keep it now and sort the bits that need doing
    Think I might give my headlights ago with that method then.
    I get my silicone from sfs on ebay seems good quality and fairly priced
    B5 tip is next for me I think
  7. Rice
    Rice Active Member
    247
    37
    Good on your bud!
    Give R tech an email, their TIP's are the same as b5 i believe, and they charged me £100 fitted when i was up there! Which i think is cheaper than the b5 tip.
  8. chaz20vt
    chaz20vt Member
    428
    21
    Ok bud will do can I ask what your map cost as im looking at going stage 2 and wanted to compare between a couple of places
  9. Rice
    Rice Active Member
    247
    37
    £290
  10. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    The seal above the front screen,does it just pull off ?
  11. chaz20vt
    chaz20vt Member
    428
    21
    Thats a really good price :)
  12. Rice
    Rice Active Member
    247
    37
    yeah, it's stuck to the screen with adhesive tape, so best pulling it upwards away from the screen. I wouldn't try replacing it with the screen in, ball ache. Ended up bending the inner metal strip slightly, but looked a lot better than cracked rubber!!
  13. Rice
    Rice Active Member
    247
    37
    So thought id carry on with my engine bay tidy up... Ordered some VHT black wrinkle paint, some m6 stainless bolts and cam cover gaskets. I chose wrinkle paint as the plastic covers in the bay have a wrinkle effect to them.
    First off, heres a before shot;
    Cam cover off and degreased, also sanded off some of the casting marks and scotched it up ready for paint
    After paint, in hind sight i put too much paint on, which made the wrinkles more pronounced and less like the oem plastic covers in the bay, i was unsure of whether i liked it, but after curing it in the oven and trying it on the engine i liked it.
    And all refitted, one of my coil packs has been replaced as there was one miss matching push-on type. I removed the brackets for the N249 valve as its been bypassed anyway so no need for it to be on there. But as the ecu gets upset if you disconnect the wire i cable tied it behind the hard pipe out of sight connected up.
    I also sprayed the m6 nuts that bolts down the cam cover with wrinkle paint, and one of the vacuum hard pipes as some tit of a previous owner polished it... probably thinking it was ali or stainless!
    Next job, replace skanky blue hoses, do something with the throttle body and inlet manifold and fit an oil catch tank.
  14. chaz20vt
    chaz20vt Member
    428
    21
    Coming on mate when you doing your hoses then
  15. Rice
    Rice Active Member
    247
    37
    Cheers mate :), ill probably order some when I get paid, they're not very expensive though, bout £30 I think.
  16. Gordie_S3
    Gordie_S3 Member
    85
    46
    Looking good!
    I always had a soft spot for white s3's....they look so good!
  17. chaz20vt
    chaz20vt Member
    428
    21
    It'll look good with them done to do you usually have a engine cover for the rocker cover
  18. AVLO
    AVLO Active Member
    295
    52
    She's looking good matey you going to AITP?. Although I've got a white s3 myself I'm jealous haha.... Keep up the good work pal.
  19. Rice
    Rice Active Member
    247
    37
    Thanks :)! Yeah I think it's my favourite colour, although maybe I'm just biased lol.
    I did, but I've left it off now as I prefer the look of the cam cover now :).
    is that the one at castle Combe? Perhaps :), if its up to scratch. Need a small bit of paint work doing on the front arches, bit of rust around the arch from it chipping off. Thanks though dude :), appreciate it.
  20. AVLO
    AVLO Active Member
    295
    52
    No it's the one in 3week at billing aerodrome?.
  21. Rice
    Rice Active Member
    247
    37
    Ahh yeah Scottb5 told me about that. Probably not! I'd be up the one at castle Combe, can't remember what that ones called....
  22. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    Combe is ADI (Audi Driver International)
  23. Rice
    Rice Active Member
    247
    37
    So finally sorted out the INFURIATING noise that was coming from my divert valve, it was like a flute noise at between -5 - 0 boost, both standard divert valves I bought from TPS were faulty, so I was fed up with it and looked for an uprated item. Found a used Forge 006p (before the 007p) divert valve on eBay for a reasonable price so got that. Turned up today. Seems to have sorted out the noise after a short drive which is a relief! And added some more bling to the bay ;)!
  24. Rice
    Rice Active Member
    247
    37
    Another boring update :)
    Drivers side window lifter wire thingy ma jiggy snapped -_-! Decided the eBay ones can go **** themselves (my passenger side one has a 14mm different in height between lifters, consequently it whistles when doing anything over 80). So got one from TPS, my god it was so simple! Just drilled out a few rivets, placed the new assembly on and rivetted to the door frame. If anyone's lifter breaks, just get one from TPS and save yourself the ballache of putting in a new wire which will probably be the wrong length between lifters and get on your tits.
    I'd first like to thank s3dave for his guide on cleaning injectors before I start the next subject...
    Cleaned the fpr and injectors in an ultrasonic bath I borrowed from work! Loads of **** came out! First I put them in redex/injector cleaner in a jar in the bath for 20 mins or so, as the sonic waves aren't as strong through glass. Then from that into the water, as the pic shows to get rid of any other ****. Then shook the water out and put them in petrol as I didn't want the water corroding them before I put them back in the next day.
    I couldn't be arsed to set up a rig type thing to see how they performed, it was just one of those things I wanted to have a go at... Maybe next time!
    Clean injectors :)!
  25. Rice
    Rice Active Member
    247
    37
    Another small update :)...
    Decided to remove the inlet manifold and spray it as it was letting the bay down...
    Heres the inlet and maf sprayed, got new gaskets and bolts from TPS, looks much with new bolts!
    Also got new DV hoses as i dont like blue hoses...
    A mate very kindly lent me his DA so i set to work on saturday machine polishing it, had lots of small scratches on it, and im pretty happy that i got the majority of them out.
    Started off with a scholl concepts high cut polish, then autoglym paint renovator, then a fine cut scholl concepts polish, then a chemical guys glaze, then two coats of poorboys nattys wax. Spent saturday and sunday afternoon - late on it, then finished it off this morning.
    DAT BEADING DOE!!!!
    Few pics i took this evening...
    Those were only taken on my phone i forgot to charge up the battery on my camera.
  26. PDBoosted
    PDBoosted Active Member
    242
    Wow... just wow!! One of the best looking S3's I've seen.
  27. Rice
    Rice Active Member
    247
    37
    Wow thanks! Really appreciate that buddy!
  28. chaz20vt
    chaz20vt Member
    428
    21
    Might aswell comment here to looks spot on mate
    You could always do mine:thumbup:
  29. S3 Rav
    S3 Rav Well-Known Member
    2,824
    30
    Very nice.
  30. jojo
    28,859
    3,518
    I still think the I/c pipes on show lets it down! Prefer them hidden, but each to their own.
    Sam_ likes this.
  31. Sam_
    Sam_ Down under
    3,037
    480
    Yeah it would look better with them hidden somehow. It's kinda more "beaten up drift s13" than tidy Audi looks wise.
    Even if they were black?
  32. Rice
    Rice Active Member
    247
    37
    I've been thinking about buying another pair of them and getting them anodised, to see how it looks.
    Thanks for the compliments though guys :)
  33. Rice
    Rice Active Member
    247
    37
    Put some bucket seats in it. Chuffed with how they look, only thing I'm not majorly keen on is the smoked chrome type eyelets (or whatever they're called). May see about getting them changed to black by some method or another...
    And a hefty 40kg saving over the recaros. Don't know if ill keep the rear bench in or not as it's pointless as no one could get back there, but I think it looks better with them in. That's the main thing I like about the look of the seats, they're very oem+ looking imo.
    Yet to take it for a drive but I'm very excited to see how they feel/support.
    slowcoach3 likes this.
  34. Westy
    Westy Well-Known Member
    17,443
    1,103
    Looking good.
    Can you give me a few details of what seats and brackets you used. Also did you have to drill some holes in the floor to bolt the seatbelt buckles down? I was lead to believe that they are originally attached to the OE recaros?
    Also how did you get around the airbag light that comes up when removing the seats?
  35. Rice
    Rice Active Member
    247
    37
    The seats I don't know the model of im afraid. I got the seats, sparco side mounts and what I believe to be universal sliders, so I didn't have to source anything, they bolted up straight to the recaro subframe. It's got spacers on one side of the seat > side mount of around an inch (haven't measured them), the holes on the bottom of the side mounts have been elongated slightly to fit the rails. And two holes were drilled at the back of the rails to fit the subframe. I think I saw 'cama' on the sliders, so maybe they're made by them? They're not the greatest sliders, but it's not like I'm going to move my seat position very often.
    It already had buckles attached to the side mounts so that's how I left it.
    I didn't actually know about the airbag light lol, I've not switched the ignition on yet. Ill have to speak with a mate who's just fitted buckets into his s3 as he's an audi technician so he should know. Ill let you know what I find out.
    If you need measurements of anything just let me know and ill do the best I can to help :).
  36. Rice
    Rice Active Member
    247
    37
    He's wired one of these into each connector.
    http://bit.ly/19rBnx5
    Ill let you know exactly how to when I come to do it myself :).
    Westy likes this.
  37. Tim_Attard
    Tim_Attard Active Member
    473
    44
    looks nice dude, i would definitely take the rear seats out they weigh a ton, you could always do something to make whats left look a bit nicer instead of leaving it with bare metal
  38. Mi11ar
    Mi11ar Active Member
    316
    35
    Love it keep up the good work :)
  39. Rice
    Rice Active Member
    247
    37
    Thanks mate :).
  40. Rice
    Rice Active Member
    247
    37
    Thought id update the thread as not much seems to be happening on the forum at the moment!
    Got new suspension on it now, the plan all along was to get uprated shocks, but then some Fk highsport coilovers came up for a price that i couldn't say no to. They're not a bad ride to be honest, and have improved the the amount of roll i get.
    Also got the front lower control arm bushes changed, the fronts i put in powerflex polybushes and the rear solid oem bushes, as they seem to be the ones people recommend.
    Heres a picture, everyone likes a picture.
    Ah that reminds me, the n/s/r caliper was sticking slightly, so decided to buy a service kit for it, in the hppe that the pistol was ok. Luckily it was, just scotched it off and it was good as new! No more sticky caliper... yay!
    Took the car back up to Niki at R tech a few weeks ago for a final tune.
    Very pleased with how the car (and niki lol) performed! Got 280bhp and 305ftlb of torque. He says its flowing very well, so he didn't need to up the boost as much, running around stage 1 boost apparently, 1.4 bar. Its good considering its only got the standard cat back exhaust on there.
    Very happy, and a brilliant drive home - albeit the terrible traffic.
    Skipped out the M5 and chose the A429 (iirc) through the cotswolds, which was a nice drive, and had good fun chasing an 07 plate boxster s down the A road.
    Standard graph picture!
