  1. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    :think: Hi just bought an s3 so new to this all. car has a revo remap 265bhp but i find that when putting my foot down and changing gears the revs take a while to come down . is this common and who knows whats wrong?
  2. S3 Dave
    S3 Dave Now running on Heavy Oil
    432
    Clutch slipping??
  3. S3 Rav
    2,825
    30
    nah it doesnt feel like it. when actually changing from 1st to 2nd say, the revs take a long time to drop down, its lke the opposite from slipping if that makes sense??:think:
  4. s3ollie
    s3ollie Member
    762
    sounds like its either your clutch switch or your maf.
    This happened to mine and a mew maf cured it but Ive seen a lot of post where it was the clutch switch located on the peddle.
  5. Starry
    Starry S3 8P stage 2+
    333
    27
    this is a fairly common problem, but there does not seem to be one answer, i tried the clutch switch which was no help. i was told that the clutch switch is only to cut the cruise control off when pressing the clutch, right or wrong i dont know,
    next i tried cleaning the throtle body and the butterfly inside as this seemed to be a possibility but still no luck.
    the last thing i tried was the n75 valve which i changed for a j type, now this is the closest ive got to fixing the problem, its not right but its a lot better and i can change gear without looking and sounding like a 95 year old with no hand foot co-ordination..
  6. s3ollie
    s3ollie Member
    762
    with mine the maf was the culprit! have you tried a new one?
  7. S3 Rav
    2,825
    30
    not meanin 2sound thick but whats a maf?
  8. Starry
    333
    27
    never tried the maf but i think i will see if i can borrow one for 10 min's and see if it improves it a little move.
    Rav, the maf is the mass air flow meter and sits between the airbox and the and the intake on the engine. its held in with two screws and a plug.
  9. S3 Rav
    2,825
    30
    so is this a common occurance then? iv just driven home now and the car doesnt feel right atal asif theres ot as much "punch" with the turbo...could this be connected?
  10. simch
    simch Active Member
    2,028
    The revving on problem is very common with mapped cars. You soon get used to it.
    It has absolutely nothing to do with the clutch switch!! Clutch switch only turns off cruise if you have it.
    You will soon get used to it, you will find that just coming off the gas, there is a slight delay also.
  11. s3ollie
    s3ollie Member
    762
    well i think there is some debate about the clutch switch heres some posts:
    Another:
    Another:
    :confused:
  12. golf
    golf ***** rent boy VCDS Map User
    1,556
    I had the same problem on my A4 (1.8T as well) whereby the revs would not decrease upon pressing the clutch, and this caused me to sound like a right amateur which I clearly am not.
    Turned out to be the clutch switch in the end, to add to the confusion around this part. It costs £8 from Audi, so it's worth a try.
  13. simch
    simch Active Member
    2,028
    Rubbish!! The problem is the throttle not closing quickly enough coming off the gas. It does it even without depressing the clutch, so the clutch switch is nothing to do with it.
    If the clutch switch cuts the revs when depressed, or closes the throttle, how come if you keep your foot on thrrottle and dip the clutch when driving, the revs stay or increase as the engine load reduces? How come you can blip on down changes??
    To the original poster, when you are accelerating and just come off the gas, (not on a gear change) does it feel like the car stays accellerating for a fraction of a second? If so, it is the trait of remapped drive by wire cars so just adapt!! One trick is to change gear a little slower and more deliberately.
  14. S3 Rav
    2,825
    30
    yea sounds bout right. think it may jst be something to get used to i guess although i may check the maf 2mos. as posted earlia just today i feel the turbo is lacking punch and sounds alot louder. any suggestions?
  15. simch
    simch Active Member
    2,028
    If you have cruise control you can check your clutch switch by seeing if crusie turns off when clutch is depressed. If it does, that is it, it works!! MIne does (ie clutch switch works) and yet my throttle stays open for a moment after coming off the gas and can "rev" between gearchanges if you grab a gear to quick.
    Clutch switch is just an on off switch, there is no potentiometer on it, so it is either on or off. If it works on cruise, it works, that's it!!!
  16. simonwjones
    simonwjones Member
    366
    hear what you are all saying, so how come my old shedof an A6 avant had a clutch switch and NO cruise control?????
    Dealer told me it was to drop revs slightly when changing gear.
    Simon
  17. s3ollie
    s3ollie Member
    762
    Im not saying it is this persons problem but... are you trying to tel me all these people who have resolved the over reving problem by changing the clutch switch that its just coincidently (magically) stopped doing it after they changed the switch. i don't think so :icon_thumright:
    and why would they fit a clutch switch to a no cruise car? mine has no cruise but has a switch
  18. simch
    simch Active Member
    2,028
    They all have them fitted, same as they all have loads of wiring etc that is not used.
    MIne had one fitted and i had cruise retro fitted.
    If anyone thinks the clutch switch does anythign else, go out and try it. light cruise, 30mph, hold throttle steady and dip the clutch. It does exactly what you would expect, ie the revs rise.
  19. golf
    1,556
    So by your logic Simch, the over revving problem on my A4 without cruise control was fixed by pure luck, seeing as though as soon as I put the clutch switch the problem was sorted?
    Even the parts guy said it was a common problem, so I don't see how you think the clutch switch doesn't drop the revs when depressed?
    This is laughable.
  20. S3 Rav
    2,825
    30
    would the clutch switch be an issue even if there wasnt cruise control on my car? and for the maf would that come up as a fault with diagnostics because it didnt.
  21. keendean
    keendean Member
    358
    My remapped car has the exact same problem, it is annoying. But I also have the problem, where sometimes I get full boost, sometimes not.
    I changed the clutch switch, with no effect. VAGCOM picked up the clutch switch up as a fault, but still over revving, as it has a panel filter, next step will be a new MAF, it can't do any harm.
  22. S3 Rav
    2,825
    30
    yea might have to try that out aswell. getting my turbo cleaned out on thursday just to tick that off aswell. like i said iv had the diagnostics on with no faults. aparently to check the MAF you can remove it and drive the car, if it feels alot better the MAF needs replacing
  23. keendean
    keendean Member
    358
    It's a servicable item as far as I'm concerned, I'm going to replace the MAF for piece of mind, then give the Forge DV a service, hopefully that will sort my boost issues too :) After that, I'm running out of options, I know the map should allow to over rev a bit, but not as much as what it's doing atm surely :(
  24. S3 Rav
    2,825
    30
    yea thats true. how would you service your dv?
  25. keendean
    keendean Member
    358
    It's on the Forge web site how to, I may go back to OEM though if it does not fix my problems :(
  26. S3 Rav
    2,825
    30
    am i being thick i cant find on the website where it talks about servicing the valve
  27. pat@forge
    pat@forge New Member
  28. S3 Rav
    2,825
    30
    cheers guys will have a look. pat whats the difference between the 007 and the more expensive one?
