  1. baztard
    baztard New Member
    Hi all just got a 03 a4 1.8t 190hp when changing gear there's a delay in the rev's coming back down any help or this normal cheers
  2. Jp-tqs
    Jp-tqs Member
    183
    Hi mate, got the same engine as yours. Cant really understand whats going on from your description!! More detail please!
  3. marktdisport
    marktdisport Active Member
    1,195
    15
    Sounds like the clutch switch is faulty causing revs to hover and stick whilst changing gears, getting it scanned might help
  4. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    As above
    clutch switch makes your revs drop
    If you have cruise you can easily check the clutch switch by seeing if your cruise works if not then thats your problem
    if no cruise you could always remove the plug from the switch bridge it with a bit of wire and if the revs drop when you drive then you need a switch
    £13 ish from the stealer's
  5. baztard
    baztard New Member
    hi mate when you rev car in neutral rev's drop normal when you driving through the gears rev's tend to hover for slight time, How does your's respond.
  6. hades-
    9,481
    646
    as the 2 above clutch switch
    cheap and easy to fit
