Revs dropping and cutting out
Andrew@A.L.D Nov 27, 2010
  1. Andrew@A.L.D
    3,877
    617
    Just started doing this, maybe its the cold but its getting annoying.
    I'll be driving down the road and come to a junction, dip the clutch and the revs drop to 400 then come back to 950rpm, some times it will cut out?
  2. HTC
    HTC Active Member
    3,428
    9
    Last time this happened to me it was a vacuum leak. Take a look at the various vacuum pipes post turbo. Also a clean up of the throttle body can cure this.
  3. Andrew@A.L.D
    3,877
    617
    Thought i had a vac leak and my MPG has been bad
  4. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,261
    357
    can a vac leak ruin your mpg?
  5. finesse
    finesse Active Member
    2,805
    hmm sounds like my crank sensor issue, vagcom scan will confirm
  6. Lemon S3
    Lemon S3 Alex
    1,390
    41
    It's probably the vac pipe under the inlet manifold.
  7. Broken Byzan
    13,237
    465
    I had this recently, went through all of the above, turned out to be the MAF.
  8. Andrew@A.L.D
    3,877
    617
  9. Sandip
    2,440
    91
    Clutch switch? Not had an issue with this switch personally but i've heard the odd story about them lol
    I would of thought it was the MAF to be honest, possibly try unplugging it and see if it still does it
