revs driving me crazy!!
dazza2393 Jun 16, 2014
  1. dazza2393
    dazza2393 Member
    53
    Hi.can anyone explain why when my car is warm the revs bounce between 1 and 2k?if i switch off and start back up the revs go to normal.the engine is a 1.6.any ideas would be great!thanks.
  2. dazza2393
    dazza2393 Member
    53
    Anybody. I've had 40 views but no one got any ideas?someone with vast experience may know?please any suggestions would be grateful.
  3. Nilz
    11,319
    872
    OK, a bit more info would help, when does this happen, when the car is idling, all the time, when you are driving?
    Has the car had any mods done to it, have you had the car scanned for any fault codes, if not, see if you can get that done first, as that could identify the issue straightaway for you.
  4. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,365
    2,335
    That sounds like a throttle body issue to me.
  5. dazza2393
    dazza2393 Member
    53
    Hi desert storm.if i took it off and cleaned it would i have to get it reset?if so is that correct in saying disconnectingy battery resets it?cheers
  6. hades-
    9,481
    646
    TB or maf
  7. dazza2393
    dazza2393 Member
    53
    How do you re align the throttle body?
  8. hades-
    9,481
    646
  9. dazza2393
    dazza2393 Member
    53
    Does taking the battery off for 30 mins not reset it?
  10. hades-
    9,481
    646
    there is a way without vcds
    someone with a 8L will tell you how.
  11. razza1
    razza1 Well-Known Member
    3,054
    804
    Sounds like it could be carbon build up on the throttle body, I had this on my old A4, do the revs increase when you're in gear and then release the clutch to change gear? If I recall it was about a £100 job to fix
  12. Joshstan
    Joshstan Member
    180
    17
    Take the throttle body off and get to work with a can of carb cleaner and a cloth and get it as clean as you can make sure you open the butterfly to get it all clean and then refit it
    There is no real need to realign with VAGCOM as it will realign itself after 30mins or so of driving
    Also check for vacuum leaks and such as these can cause rev bounce
  13. dazza2393
    dazza2393 Member
    53
    Hi guys.cleaned tb with card cleaner its clean as now.however............the dreaded bouncy revs are still there.checked all pipes etc no leaks.so what am i looking at a new maf or maybe egr valve clean or can anyone suggest????thanks lads in advance....
  14. hades-
    9,481
    646
    pull maf plug.
    see if the revs are back to normal if they are its the maf if not keep on looking.
  15. dazza2393
    dazza2393 Member
    53
    Ahhhhhh thanks mate.never thought of that.cheers.will keep updated.
  16. dazza2393
    dazza2393 Member
    53
    Hi Bez mate.the rev thing did i thang today so unplugged maf and the revs did the same.they did not die off.its proper doing my head in now mate.what else could it be.?would plugging a fault code reader in show up anything?
  17. hades-
    9,481
    646
    it could do
  18. Joshstan
    Joshstan Member
    180
    17
    Get it plugged in is by far the best thing to do next
  19. dazza2393
    dazza2393 Member
    53
    Ok.will have to buy one off ebay 1st.cheers
