Revo stage 1 - what are your Performance Mode settings?
elton121272 Aug 4, 2010
  1. elton121272
    elton121272 Active Member
    393
    163
    43
    As the title says ther are 3 settings for:
    Boost/Throttle Response
    Timing
    Air Fuel Ratio
    Just wondering if the settings were standard to all stage 1 re-maps from revo or what the general consensus was if varied?
    I have a '10 plate S3 SB BE which is totally standard.
    Thanks in advance.
  2. Pii
    Pii Member
    748
    A lot of the guys here have different settings although I'm not sure how it's changed.
    Can anyone confirm?
  3. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Im running these on REVO Stage 1, very happy with peformance and delivery characteristics although I have never done any logging so not sure about correctional factors.
    Boost - 7
    Timing - 6
    Fuel - 9
    Car is ALWAYS filled with V Power (99 ron).
    Good luck
    Paul
  4. KRL
    KRL Member
    521
    Hi Paul, from experience of doing lots of logging myself I would suggest you perhaps take the timing back to 5 in the hotter weather as I would imagine you are pulling a fair amount of CFs unless you have an uprated intercooler installed?
  5. Pii
    Pii Member
    748
    KRL how do you actually change the settings?
  6. KRL
    KRL Member
    521
    REVO supply a device called an SPS Plus. It allows you to adjust fuel, timing and boost. You can also use it to put your car into stock mode, valet mode or anti theft mode.
    Great bit of kit :)
  7. Pii
    Pii Member
    748
    Do you mean the select switch thing?
  8. KRL
    KRL Member
    521
    Yes. There are two of them though. The Select switch only allows you to switch between pre configured settings but does not allow you to tweak boost, timing and fuel. The Select Plus does allow you to tweak boost, timing and fuel.
  9. Pii
    Pii Member
    748
    Thanks KRL - Think I'll go dig out the old box to see which one I have. Might be lucky as the switch was a hand me down. Fingers Crossed lol.
  10. elton121272
    393
    163
    43
    Here is what I think mine are set for - how do these compare?
    Boost: 6 (Performance boost)
    Throttle Response: 5 (increased response)
    Timing Adjustment: 5 (predominantly for 98 Octane fuel with occasional 95 octane use)
    Fuel Adjustment: 9 (Performance Air Fuel Ratio)
  11. Pii
    Pii Member
    748
    I only have 3 settings on mine: boost, timing and fuel.
  12. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Thanks mate, need to get me a Select+.
    Paul
  13. BOSSS3
    BOSSS3 Member
    119
    My settings are:
    B7
    T3
    F9
    On 95ron fuel.
  14. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    95 Ron - your just not doing the car a justice!
  15. BOSSS3
    BOSSS3 Member
    119
    Cannot get anything else where i live unless i go to the coast and there they only have 98 Ron.
  16. finesse
    finesse Active Member
    2,805
    Mode 3 - R6
    Mode 4 - R5
    Mode 5 - R5
  17. dean_watford
    dean_watford Member
    70
    Just bought a Select Plus for a 2.0TFSI which is REVO1'ed. It is in for a service Weds so going to ask them what setting are on it at the moment.
    Does anyone else have a plus w 2.0TFSI? Just wondering what settings people are running??
    I find the current performance patchy - sometimes it feels v quick, other times not so.
