REVO stage 1 - Performance mode setting help please....
elton121272
Glasgow
Hi Guys,
As per title, what settings do you guys have on Revo stage 1.
I currently have a full Milltek TBE fitted but no air filter so still at stage 1.
What are your settings for:
Boost/Throttle response -
Timing -
Air fuel ratio -
Thanks in advance guys.
Cheers.
What quality fuel do you use? Higher settings with higher ron petrol. Best to do some data logging and see what is best for you. But even if you use too high settings the ecu will adjust accordingly
4 out of 5 its V-Power and the other 2 its that '99 ron stuff from Tesco....
Does that and the TBE zorst suggest different settings from above?
Cheers.
Stage 1 with intake only for me.
B9
T5
F9
I also have on the select B8 and B7 with the same T & F as above.
Boost 9 is the only way!
